L@@king to buy a Cheap Borg Warner 4405 Transfercase
My transmission problem keeps getting expensive. As it turns out after rebuilding the entire transmission, there was a grinding noise when coasting. Cause, as I found many posting in several, buleting for Ford trucks, a faulty transfercase.
Does anyone know of a please where I can find a cheap, rebuilt or if anyone has a spareone collecting dust in a shed or garage somewhere Please let me know.
I have a 95 Explorer Limited 6 cylinders 4.0 4x4. Which I think uses a Borg Warner 44-05 Transfercase.
Thanks
Ed
Thanks
Ed
first there are 5 style of 4405 3 (control trac) 2 (AWD) there is a letters after the 4405 like fa ga ca ... now it can also be the shifting forks bad most you pull are $100 for t-case others want $500 for them if you can installit if not have it rebuilt it will cost $500-$800 as long as the bushing is not bad in the t-case for the helecut gears
uncle junk
19
08-30-2015 01:38 PM
Blackfoot Big Block
07-28-2011 07:02 AM
Silver Bronco
12-14-2003 01:51 PM
crazy4Fords
04-04-2003 11:07 PM
