Header Coating - Ford Truck Enthusiasts Forums
Header Coating
Old 01-15-2014, 11:30 AM
Branded's Avatar
Branded Branded is offline
Branded has a good reputation on FTE.Branded has a good reputation on FTE.
Header Coating
I have a set of Sanderson ceramic coated block hugger headers on my 54 with a 302 that needs to be recoated. Who have you guys used ?
Old 01-15-2014, 11:46 AM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
There are many local shops here in SoCal that apply the coating...you may want to check you local shops to see if they can help you. Most of the powder coating shops around here do JetHot and other ceramic coatings now.
Old 01-15-2014, 12:12 PM
Branded's Avatar
Thanks Charlie, I'm near Cincinnati Oh, one would think there would be some place in Cincy that provides ceramic coating but all I'm finding local is powder coating. Looking for someone that has had experience with a vendor that will do a good job. I found several doing a Internet search but as we all now that can be a crap shot.
Old 01-15-2014, 12:48 PM
CharlieLed's Avatar
Small world, I grew up in Cincy...NCH to be exact. My buddy and his sons run a body and restoration shop in Batesville Stoinoff's Auto Restorations - Home you could contact them and see if they have a vendor who could help.
Old 01-15-2014, 02:53 PM
Branded's Avatar
Charlie .. I know the body shop your talking about. I'm only 15 minutes from Batesville. If I don't find someone to do the coating I may call them. I have a lead on a place near Dayton but haven't called yet.
Dave
Old 01-15-2014, 10:08 PM
CCPcoatings CCPcoatings is offline
CCPcoatings is starting off with a positive reputation.
Quote:
You're saying "recoated". What is on them now and what is wrong with the current coating?
Old 01-15-2014, 11:22 PM
Branded's Avatar
Quote:
They are ceramic coated and have what I'll call rust pimples or spots on them.
Old 01-16-2014, 12:04 AM
So I'm assuming these are polished ceramic. Not sure how old they are but I would bet that they are not very bright any longer.
As a general rule, bright coated "shorty headers" don't hold up very well unless the engine is in PERFECT tune and they are in an open air / street rod application. You're better off with a high temp ceramic, but unfortunately this does not include the polished finish.
The reason they fail is because the headers are so short that they are not much longer than the flame front. Even in perfect tune they get overheated, dull and the pores open up causing the little rust spots you are seeing.. On full length headers you'll generally find that the first 8-12 inches of primary dull as well but they are longer and dissipate the heat better.
Old 01-16-2014, 12:54 AM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
I did high temp ceramic cast grey at my local powder coaters.
Old 01-16-2014, 07:15 AM
48 Steel's Avatar
48 Steel 48 Steel is offline
48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold
I had my Sanderson headers done at a local company (Luftkraft Fabrication). They used Hi- temperature Chromex.
____________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"Beware of High performance trucks with low performance drivers"
Old 01-16-2014, 07:16 AM
Branded's Avatar
CCPcoatings... Thats what I'm dealing with but not that much rust. The headers have been on the truck probably 12 years.
Old 01-16-2014, 07:18 AM
Branded's Avatar
Quote:
Originally Posted by 48 Steel View Post
I had my Sanderson headers done at a local company (Luftkraft Fabrication). The used Hi- temperature Chromex.
How much $$ did they charge to recoated if you don't mind me asking.
Old 01-16-2014, 07:36 AM
48 Steel's Avatar
$275 and I think they do out-of State but the shipping will cost.
Old 01-16-2014, 08:27 AM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
I used a company called TOEFCO in Niles, MI. Not far from Benton Harbor. It was 12-13 years ago, so I can not remember what it cost. I had silver ceramic coating put on headers from a 92 T-Bird that fit nicely with my 351W/C6 on my 56 F100. Photos in my gallery show LH and RH shorty headers.
460 chassis headers?????? william16339 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-22-2016 04:55 AM
ATF coating headers chiefsfootball 1967 - 1972 F-100 & Larger F-Series Trucks 42 07-23-2015 06:14 PM
headers greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-11-2015 01:23 PM
Headers for 1979 F250 supercab 4x4?? fishindave11 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-19-2011 05:23 AM
390 headers for a 4*4 Drabbit FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 33 02-01-2010 06:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
