'50 Inner tube - Ford Truck Enthusiasts Forums
'50 Inner tube
Old 01-15-2014, 09:29 AM
saxtonj's Avatar
saxtonj saxtonj is offline
saxtonj is starting off with a positive reputation.
'50 Inner tube
I want to use the original 16" wheels on my '50 F-1 and need to get tubes. What size valve is used on the inner tube to match the hole in the wheel... TR15?
Old 01-16-2014, 12:07 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Either the small or the big one. I really don't
remember but a 16 prolly takes the bigger stem.
Ya can always drill it out for the bigger one. Be sure to smooth
the edges if ya do drill it oversize.
Old 01-16-2014, 12:40 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
These have worked on my '49 with stock 16 inch wheels and bias ply tube tires.
165/185R16/400 Radial Tube - TR13 Offset Rubber Stem
DW
Cheap steel inner wheels - DRW lee00 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-22-2015 10:15 PM
What are you using for tailgate chain covers? Skalywag 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 06-09-2015 03:03 PM
Dana 60 Outer Tube dust seals '97 F-350 non vacuum seals Knewstroke97 1994.5 - 1997 7.3L Power Stroke Diesel 8 11-28-2014 07:43 AM
Wheels and tires for 51 F3 justrob 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 09-02-2014 09:09 PM
Dana 60 Bearings & Seals redman84 1994.5 - 1997 7.3L Power Stroke Diesel 22 11-30-2013 11:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
