instrument cluster light not working - Ford Truck Enthusiasts Forums
Old 01-14-2014, 10:04 PM
jwsrules jwsrules is offline
jwsrules is starting off with a positive reputation.
Hi i got a 2001 and the instrument cluster doesn't light up, i changed the fuse and it suppossed to be 5amp and i tryed a 10amp and it blew it a couple seconds after i turned the lights on, What you think could be causing this?
Thanks
Old 01-15-2014, 08:20 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
You have a short circuit in the instrument illumination circuit. Quit putting in oversize fuses, otherwise you will let the magic smoke out of the wires that the fuse is protecting.
Unless you know of some recent work (radio install, for example) to investigate, finding a short circuit will be a PITA even if you know what you're doing and have the right test gear. If you don;t know what you're dog and don;t have the right gear, your only realistic choices are a visual examination for wiring faults (bare wires touching ground or a wire under a screw or something similar) followed by taking it to someone who is properly equipped.
The wire for the cluster illumination circuit output from the dimmer control should be light blue with a red tracer.
Old 07-02-2014, 02:24 PM
kdwellssr's Avatar
kdwellssr kdwellssr is offline
kdwellssr is starting off with a positive reputation.
I have a 98 F250 and would like to know if All the instrument clusters have the 4x4 light option? My Odometer stopped working and I am planning on getting another... Just wondering if it must come out of a truck that has 4x4 or the proper operation?
Old 07-03-2014, 12:43 AM
73fan's Avatar
73fan 73fan is offline
73fan has a good reputation on FTE.73fan has a good reputation on FTE.
I cannot directly answer your question, but I think they would all have it. I noticed that mine has a few lights that are exclusive to a few options mine does not have.
Sent from Nexus 4. IB AutoGroup
instrument cluster problem on amp cluster ( not dummy light cluster) BORDERBUM 1973 - 1979 F-100 & Larger F-Series Trucks 11 05-25-2015 11:05 AM
my instrument cluster lights wont work victor9909 1987 - 1996 F150 & Larger F-Series Trucks 0 04-23-2015 11:12 PM
Help! changed cluster & truck wont start supersmith 1997 - 2003 F150 1 11-29-2014 04:43 PM
Instrument Cluster Lights Out ZackWarning 1987 - 1996 F150 & Larger F-Series Trucks 3 10-07-2014 11:19 PM
Instrument Cluster Lighting Issue GooseStick 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-06-2014 12:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
