Glow plugs keep cycling.
Today I went to fire my truck up and everything seemed normal. The plugs cycled for about 8 seconds then the WTS light went out. I started the truck up and they kept cycling like normal. But usually it only does it for about 2 minutes while the trucks still cold. But I got to driving and they just kept on cycling even though the motor was warmed up at that point. So I came home and even after I shut the truck off they still kept cycling. About every 10 seconds they will come on and click. I unhooked the battery cables so the wouldn't go dead. I'm guessing it's the GP controller but not to sure. How can I trouble shoot it and fix them from keep cycling. Thanks
I found out the clicking is comming from this thing that's bolted to the fire wall. Not sure if it even has anything to do with the GP controller
I'm not sure what it was. the previous owner must have put it on. It made the same clicking sound as my controller and was ran to a switch inside the truck. I unhooked it and no more clicking and draining the battery. Thanks for your suggestion anyhow.
Well that wasn't the end as I had hoped. Went to cold start it after unhooking it and the truck did not want to start at all. It has to have something to do with the GPs. It's like I didn't have em. The WTS light still came on for about 10 seconds though. But if I hook this thing back up it does the same thing before I unhooked it and drains the battery but starts fine. I would post a pic but not sure how off my iphone. Any suggestions ?
on
is your truck still the '94 like your screen name suggests?
it sounds like you removed the power supply going to the GP controller off from the fender mounted starter solenoid.a ring style terminal with a fuseable link which is on the always powered side.
that was a wise move actually.you probably saved your glow plugs.
you can fully diagnose the system here:
https://www.ford-trucks.com/forums/1...-tutorial.html
to temporarily start your truck (while you wait to order a new gp solenoid or controller,if needed) simply hook the ring back to the solenoid like it was.start the truck (as if you always do when working correctly) and while still running,remove the ring terminal again.
you wont need the gp's (ignore the WTSL) for the rest of the day,unless it's cold and has been sitting.in that case then just repeat.
on
so someone mounted a relay/solenoid on the firewall and to glow the plugs,you have a devoted switch/push button that you press/hold to glow the plugs it sounds like?
well,i know what i would do.id rip the additional manual mess out and fix the oem system.it lasts for 20+ years and it just works issue free.someone probably used a starter solenoid.take a look at it and i bet you'll see a little S on a post.
http://s880.photobucket.com/user/_ed...a4fa1.jpg.html
That's the thing I'm taking about on the firewall. And whAt do you mean someone probably used a starter solenoid "s" on what? I appreciate your help man
Received 3,101 Likes
on
