I had the same issue one day a few years back. Underwarrenty it was a EGR temp sensor. Made the truck go into a limp mod kinda. Check light and low boost. Hope you get it back on the road.
Thanks.should be picking up truck tomorrow so only time will tell if all will be corrected with the new egr
Ok so was expecting truck back today as they ordered new egr and housing and just got delivered yesterday.was suppose to get truck back today but they called and now ordered new dpf to put in it.hoping tomorrow as alot snow coming
Finally got truck back today.the dealer replaced the egr,then still truck had codes p2463,p246c showing i guess so they put a new dpf in and egt sensor.they also found these 2 tsb's apply 9-19-10 & 12-6-8 which i cant even find the second one for a f350.
