How many miles on your 6.4 and what issues had?
89000 on an f-550 4X4. Complete overhaul due to lost compression on 8&5. a/c compressor locked up gonna fix it this weekend.
https://www.ford-trucks.com/forums/a...1&d=1442623012
130,000 on mine, 122,000 when I bought it a year ago.
Alternator failed one month after I purchased.
Radiator leaked two months after purchase. When I changed it out I went a head and put in new thermostat, hoses and coolant.
This summer I had a vibration in my drive line so I replaced my carrier bearing and U-joints.
I removed DPF and EGR before I had any issues.
Been a great pickup and fun to drive. I love everything about it!
JEff
JEff
2008 6.4 with 246,500 miles. DPF delete at 100,000 made this a completely different truck. Oil change every 5K. Main problem has been 4 radiators replaced, but the aftermarket replacement has a lifetime warranty so all I pay for is the labor to install. Some new 4 x4 hubs and front wheel bearings here and there but I love the truck! It is all about how you drive and maintain them. DELETE THE DPF and you will have a good truck
Had a job 1 bought with around 70K and traded just before 130K after almost 5 years. From memory:
The small turbo went out shortly after purchase
Both belt tensioners failed at different times, I think idlers were also replaced with at least one of them
Radiator hoses sprung leaks so were updated to 2 O ring style
There was another leak around the EGR
LPFP failed around 120K (never had a drop of water come out of it during draining)
Thermostats were showing signs of hyperextending shortly before trade in (throwing corresponding codes)
Front ball joints all replaced around 120K
Might sound bad but was far better than the 6.0L we had before it. Engine grew a lot of oil from 70K-100K before I deleted it. 100K miles of diluted oil had me worried enough to trade it in, truck cost less than $13K in depreciation so was well worth it.
2008 Short Box Crew Cab 4x4, 89,000+ miles, 4" Lift. Other than a cruse control, I've been blessed. Mine only wants Batteries, Brakes, Oil and Diesel (10.5+/- MPG in town, 14 HWY). The only issue I've had lately is the DPF doing its simple regeneration two to three times a week in town. It does a major regen every 150+ miles.
I would like to do a DPF Delete, but Clark County Nevada says no.
