Front Caliper Removal Help.. - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 01-14-2014, 05:35 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
My 2008 needs new front brakes. The front caliper has what looks like hex bolts that hold it on. Does anyone know the exact size tool I need?
Old 01-14-2014, 09:58 PM
jdm5630 jdm5630 is offline
jdm5630 is starting off with a positive reputation.
I believe its a 9mm
Old 01-15-2014, 10:50 AM
berry1234's Avatar
It is 9mm. Thank you. Got the brakes and rotors on today. Original rotors have a ton of material on them, even after 135K miles.
Old 01-17-2014, 05:29 PM
Where did you buy your rotors?
Old 01-17-2014, 05:44 PM
berry1234's Avatar
Amazon. Raybestos heavy duty. They were about $50 ea, free 2 day shipping with prime. Heavy suckers.
Old 02-18-2014, 10:59 AM
amstel78 amstel78 is offline
amstel78 is starting off with a positive reputation.
I have to replace my rotors soon. How did you get the two large caliper bracket bolts off? I can't seem to get enough leverage to break them free. Also, what are the torque specs for those bolts? I think I read somewhere that they're around 135 foot pounds; does that seem right?
Old 02-18-2014, 12:24 PM
berry1234's Avatar
Large ratchet with hex driver. Took a bit but they came off. Try PB Blaster if that doesn't work.
Not sure on the torq settings. Hard.
Old 02-18-2014, 12:28 PM
Hex drive? I'm not referring to the two small 9mm hex head bolts that secure the caliper to the caliper bracket, but rather the two large 18mm bolts that hold the caliper bracket to the hub.
I'll try the PB blaster over the weekend.
Old 02-20-2014, 09:14 AM
cstanley44's Avatar
cstanley44 cstanley44 is offline
cstanley44 is gaining momentum as a positive member of FTE.
This project is on my radar for the upcoming weeks.
Ive not bought the rotors yet but do they require the bearings to be moved to the new ones? Or do they just slip over a hub.
Mine is 2wd.
Old 02-20-2014, 09:46 AM
Mine is 2wd.
No need to work on bearings. Just remove the old rotor and slip the new one on. It'll slide over the lugs and onto the hub. Reattach caliper bracket, then caliper. Bleed if necessary. Should be a fairly painless process except for the removal of the two 18mm caliper bracket bolts and the rotor itself if rusted to the hub.
Old 02-20-2014, 04:27 PM
Phil-turbodiesel Phil-turbodiesel is offline
Phil-turbodiesel is gaining momentum as a positive member of FTE.Phil-turbodiesel is gaining momentum as a positive member of FTE.
Quote:
I have a long breaker bar but use the two wrench method often
Old 02-20-2014, 05:00 PM
Thanks for the tip on the two wrench method. I'll give that a try. I tried getting my 18" long 1/2" drive breaker in there and I just couldn't get a comfortable grip to really torque them off.
I'll also hit the bolts with some PB blaster before I attempt again.
Old 12-17-2014, 12:20 PM
david_jr david_jr is offline
david_jr is starting off with a positive reputation.
Berry just to clarify, you got 135K out of your brakes? How hard were the old rotors to get off?
Old 12-23-2014, 12:44 PM
mot250 mot250 is offline
mot250 is starting off with a positive reputation.
Ford uses a tread lock (blue) on those caliper mounting bolts according to brake jobs I've done on my other 2006 and 2007 Ford cars (Mustang and Crown Vic). You could try heating the bolts a bit to loosen the grip of the threadlock. For the cars, I've been able to get them loose with a normal 1/2 drive breaker bar but I have a length of pipe that fits over the bar when necessary to extend its length.
For front brakes, it is helpful to have both front wheels off the ground and then turn the steering wheel to the right or left to get a better angle at those bolts.
Old 12-24-2014, 04:05 PM
gwcloud gwcloud is offline
gwcloud is starting off with a positive reputation.
When those disc brake caliper brackets bolts are too tight for a normal wrench I use a 4 pound hammer on the wrench. Works good and saves knuckles if the wrench slips.
A snipe works good too but sometimes there is not enough room.
Richard
Caliper rub Jtsarby Brakes, Steering, Suspension, Tires, & Wheels 1 04-01-2016 10:31 PM
2003 Brake Caliper Sticking daveplot 1997-2006 Expedition & Navigator 6 08-21-2015 05:46 AM
Calipers need replaced? Tawn 6.4L Power Stroke Diesel 7 05-13-2015 12:18 AM
Caliper piston over extended? jgilrfr 1999 - 2003 7.3L Power Stroke Diesel 5 10-09-2010 11:02 AM
Front Calipers rticwrrior2000 1978 - 1996 Big Bronco 5 12-21-2002 02:16 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
