For those concerned about the aluminum bodies:
I wonder what impact "longer life" vehicles will have on future sales of new vehicles.
In the wake of "cash for clunkers" used vehicle prices went up, and so did demand for new vehicles.
Making vehicles with aluminum should extend there useful life which would reduce potential sales in the future.
Will all the advanced electronics live as long as these new vehicles.
Hum
Sent from my Sprint PC36100 using IB AutoGroup
Hum
The newer International Prostar/LoneStar uses a steel cab. I'm not sure about Freightliners new models like the Cascadia or the Coronado.
ETA.. one of my friends works in the body shop at a Ford dealership and he told me that they need to go to school to learn how to work on the new F150's and they have to buy some special welders to work on the aluminum. I guess the equipment is pretty pricey.
Hum
Hum
In regards to aluminum, I raise rodeo bulls and haul them all across the country. The trailer of choice?? all aluminum with steel hitch and steel axles, these trailers weigh in at over 30K when loaded with animals and feed. They have held up beautifully, as far as denting them, these trailers are definitely a thicker sttronger make than will be the truck body, frames though will be very strong IMO (at least i certainly hope to see it happen). The walls of the trailers see steel gates slung into them daily and bulls running into them and they still look new. I love aluminum and am very anxious to see the outcome and hopefully the future of trucks.
The 05 and up Mustangs have an aluminum hood. I have an 07 and I can't tell any difference between it and steel except before I put struts on it you could tell it was lighter when lifting. The one problem with them is apparently they were built in the same factory with steel body parts and iron dust settled on some of them and you guessed it, rust at the seams.
Yeah Tim posted a great link to illustrate the strength of the aluminum that is used for the USPS. I posted in another thread that in the 6.5 years I worked on F16's (whose airframe comprises of milspec grade aluminum) that those things stood up to harsh combat conditions/manuvering and the elements and took it all like a champ. Thats OLD compound tech aluminum (aircraft in service since the 80's-90's) and if that stands up soo great just think about the advances in metallurgy between then and now and the compound mix they will use for the 2015.
For those concerned about the aluminum bodies and other features this article may help.
All-New Ford F-150 Redefines Full-Size Trucks as the Toughest, Smartest, Most Capable F-150 Ever | PowerNation
This is an interesting thread. Both the Freightshakers I drove at one company, as well as the Kenworths I drove at another had aluminum cabs. Of course it can hold up well over time, but I think corrosion protection is mostly a function of the coatings used. I can say that if Ford uses the same kind of coatings that they use in a heavy truck nobody will be disappointed. That stuff is TOUGH.
But if they use a coating similar to what's used now I can see corrosion happening. I would be surprised if they didn't borrow from the heavy duty coatings that are in use everywhere else.
#28
#29
VW has been using aluminium bodie parts for years now and we dont hear of many issues.They are one of the most expensive to insure in there class because cost for parts. I understand its a German product but its not only the parts that is the concern also the quality and miticulous attention to prevent contamination when working on these vehicles.
This will mean the first couple years for the service shops there will be a learning curve to go through. For me as long as dont install 5 or more air bags at 5000$ each to replace that should also help keep insurance lower .
#30
