check engine light - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
check engine light
Old 01-14-2014, 10:20 AM
farwhitenorth farwhitenorth is offline
farwhitenorth is starting off with a positive reputation.
check engine light
My check engine light came on the other day. In reviewing the owners manual, it just stated to fill up the gas tank and do 3 "cold to warm" start ups and if this doesn't take care of the problem to take it to the dealer. Does anyone else have any idea on things I can check before taking it in?
Some info:
We had been doing a lot of tree work and I had been pulling a 16' GN dump trailer with only brush when the light came on. All maint is up to date at 29,000 miles. I have noticed on colder mornings the tank doesn't like to take the first couple gallons of gas so I'm thinking it has a plugged vent. This may be the problem.?.
Thanks!!
Old 01-14-2014, 05:42 PM
Big Vic Big Vic is offline
Big Vic is starting off with a positive reputation.
Make sure that your gas fill cap is on tight (a few clicks) and the seal is still good. That can also trigger the check engine light.
Old 01-14-2014, 07:54 PM
willtim1234 willtim1234 is offline
willtim1234 is starting off with a positive reputation.
What is a "cold to warm" start up?
High Fuel Rail Pressure bradtm16 6.4L Power Stroke Diesel 21 04-30-2016 12:48 AM
Truck reduced engine power DSun 6.7L Power Stroke Diesel 7 07-13-2014 05:13 PM
1990 460 propane issue 460jared96 1987 - 1996 F150 & Larger F-Series Trucks 5 01-16-2014 01:04 PM
Check Engine Light (P401 Code) DOGSINIT 1999 to 2016 Super Duty 7 11-28-2010 05:47 PM
1990 F150 Intermittent Check Engine Light TrucknFool 1987 - 1996 F150 & Larger F-Series Trucks 12 04-13-2004 01:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
