timing for propane - Ford Truck Enthusiasts Forums
timing for propane
Old 01-13-2014, 07:40 PM
joey2fords's Avatar
joey2fords joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.
timing for propane
i have a 1994 f250 351w c6 auto on straight propane. i need to get it though an emissions test so i want to check the timing.
my question is where is the timing supposed to be on this setup .
i am also assuming that this engine uses a spout connector and that it should be disconnected in order to check and set timing.
any propane guys out there .
p.s. my keyboard cannot produce question marks or hyphens, so i am not as dumb as i appear in text .
Old 01-14-2014, 12:36 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
gasman6674 is gaining momentum as a positive member of FTE.
Depends, If the dist was recurved approx 6deg over gasoline intial. If not or it is not limited in some way no more than 3 or 4
The problem is total advance. Most LP engines run best at 28-32 degrees total advance.
Good Luck
Propane Conversion on my Edge - 6 month report PaulsEdge Alternative Fuels, Hybrids & Mileage 7 01-09-2017 08:09 AM
Propane help rempel429 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-20-2015 06:46 AM
timing on propane engine joey2fords Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 04-14-2014 01:06 AM
Bullydog Propane Tank jonnybronco Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 03-07-2014 12:27 AM
1990 460 propane issue 460jared96 1987 - 1996 F150 & Larger F-Series Trucks 5 01-16-2014 01:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
