turn signal blues
No way, really?
With the hazards on all the turn signals are blinking and it shows up on the dash. I have replaced turn signal bulbs a little while back as well.
To be very candid with you, you need to avoid cam replacement kits at all costs. They require you to slide a butt splice or solder joint into a very tight space. This also changes the effective length of the wiring in an area where there is little room for error and easy to get things pinched. This is likely to be your problem. The appropriate solution is to replace the turn signal switch entirely.
Check BOTH sides of the turn signal fuse just to be safe, but what you're working with is ultimately a hack with a marginal success rate that should be gotten rid of regardless.
I soldiered in the the wires well. I figured since the part was removable, and only the cam was the problem, it was not a problem to switch them out. If there is no way to go ahead and fix how it set up, A bigger hack will have to be installed until I can save up the 60 needed for a actual new switch assembly.
My dad just sent me a text saying he sparked my gauge cluster wires while he was fooling around in my truck this weekend, so I shall check the fuses tonight.
Just because I'm new to all of this FMC400, on a scale of 1-10, 10 being the worst, how bad is it to replace the cam rather than the switch?
I would say it's a 10 out of 10. Unfortunately, even the best of solder joints can still be problematic, because you're placing on the order of 3/4 inch of non-flexible conductor in an area where space and flexibility is critical. This also places added stress where the wire exits the joint. The all-metal column is also an unfortunate area to rely on shrink wrap as an insulator since it's easy to leave a spur on a solder joint if you're not cautious.
If you can make it work and save money at the same time, great, but that's not usually the case with this particular repair. If you have power on both sides of the fuse, it's time to pop the wheel and pull things out to see what's what. Companies make the cam kit because they'd rather get your $10 rather than someone else get your $80.
Well if I have power on both sides of the switch, I'm going to be sol for a while. I thought I was attempting to fix it correctly by taking the time to pull the wheel, solder the joint, etc. It may just have to be bypassed for a while for a 3 position switch until I have the money to put a new turn signal switch in
My instructions call for checking power on both sides of the fuse. I'm confused why power as it is distributed in the switch is being brought up at this point. The cam itself should have a pair of leads as well as a set of whiskers that control where the point downstream of the flasher is pulled to ground through the bulbs once the lever is engaged. There aren't "sides."
