NY: 1978 F150 4x4 F150 Standard Cab 8' - Ford Truck Enthusiasts Forums
Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Old 01-13-2014, 05:37 PM
LI250's Avatar
LI250 LI250 is offline
LI250 is gaining momentum as a positive member of FTE.LI250 is gaining momentum as a positive member of FTE.
Year: 1978
Make: Ford
Model: F-150
Price: $5500
Mileage: 130000
Color: Brown/White
Private or Dealer Listing: Private Listing
Location (State): NY
Transmission: Manual
Drivetrain: 4WD & AWD
Color: Brown
Engine: 400
I could go on and on about all the work and all the money but I won't. If you're interested PM me and we'll talk over the phone. I'll never get my money out of it but I don't want to part it out. ODO has rolled so Im not sure of milage. Best guess is 130000
$5500 negotiable.
1/27 How about $4800
This is a good solid truck that I bought as a project but since my family is ever expanding a pickup just doesn't make sense so I'm building the Bronco instead. If I had the storage space this truck would not be for sale.
It runs down the highway perfectly and rides incredibly smooth for what it is. Suspension keeps it smooth and exhaust keeps it quiet. If you should own a refinery you would have no problem daily driving this truck.
Specs
400. Not stock engine. Still have the original 351M
NP 435 4 speed Manual
NP 205 Transfer Case
Dana 44 front axle 3.50's
Ford 9" rear 3.50's open carrier
315/75R16 BTG AT's on Mickey Thompson 16x8's
Standard cab 8' bed
The Bad
Rust on the roof. If you know the truck you know thats not easily fixed.
Rear end leaks a bit
Oil pan leaks a bit cause I'm a dick and didn't install the gasket right. Good news is there is plenty of room to replace it in the truck.
What hasn't been rebuilt.
The tranny 4 speed manual. Still works fine.
The transfer case. No issues there either.
The axles. Rear outer bearings were done when I bought it but as far as I know everything else is stock. This was next on my list. I have had the truck for 3 years and 7000 miles and its always made a little noise but never got any worse so I left it for now.
Whats new and by new I mean replaced in the past 2 years.
Engine. Its a remaned 400 with T Meyers flat top pistons and a mild Elgin cam. It makes good power. :evil Its surprised a Ram or two.
Wieand Stealth intake.
Edlebrock 625 carb
Hooker headers, Walker stainless mufflers (quiet) full aluminized custom bent exhaust with nice stainless tips
Clutch and throwout were done during motor swap. Flywheel was resurfaced and a new ring installed.
Ford 3G modern alternator
Battery
Heater blower motor
Hoses
Front brake calipers, pads, proportioning valve, rear drums have been completely rebuilt. Brake like on the axle. The rest of the lines were done by the PO.
Mater cylinder, booster, and stainless lines from the master to the prop valve.
E Brake cables
Tires and wheels
Warn locking hubs and front wheel bearings.
Borgeson Steering shaft.
The suspension. This is where it shines. Deaver 4" springs all around. Skyjacker Monotubes at each corner. New radius arm bushings (poly) at the frame and axle ends. Adjustable Trac bar. Rides like a dream. Would probably really kick *** off road if thats your thing.
The cab. New ACC carpet and nicely recovered dash pad. Not LMC bs. Upholstery shop quality. Modern stereo with CD, USB, iPod, and Bluetooth as well as decent speakers. Seat cover is LMC bs. Seat needs to be recoverd. Door panels kinda suck. Wood grain dash is new. Door weather stripping is good. Glass is all original.
Body. Panels were replaced and it was painted in '08. Not perfect but a wet sand and buff would really make it look good. Minor rust here and there but no rot. Cab roof is rotted. Hard core rot. It needs a roof. I used the truck as a truck so the bed shows use but nothing excessive. It has a heavy duty rubber mat. Trim isn't too bad. Front grill surround needs to be stripped and polished.
What was next on my list? In order of priority.
Drop pitman arm and an alignment. Tie rods and drag links are good but if your doing the alignment...
Driveshaft U joints front and rear. Just because
The rear.
Window seals. It whistles.
Clean up the wiring under the hood
Oil pan leak. Not that bad but if you had a new driveway you'll want it fixed.
Front axle outer seals and ujoints. Driver side is wet. U-joints because its coming apart to do the seals.
What it comes with. Anything in my garage with a Ford Stamp on it:loll
Brand new brake lines for the front axle.
Full wide windshield trim
Full XLT Lariat tailgate trim
A good C6 with transfer case adapter and torque converter
2 spare Grill shells
Random side trim
Boxes of little bit and bs.
Original motor if you want it
Rear window glass
Crome non step Ford bumper
Old 01-14-2014, 09:26 PM
Ridenred333 Ridenred333 is offline
Ridenred333 is starting off with a positive reputation.
Wow I love the truck its nice. I will trade you 1 good ********, no 2 good ********* they have produced three great blond haired blue eyed kids. I dont need them anymore. Contact me if interested. LOL
Old 01-15-2014, 12:44 AM
LI250's Avatar
LOL. Sounds like a smoking deal but my ********* also produce blonde, blue eyed kids.
Old 01-27-2014, 09:55 AM
LI250's Avatar
How about $4800.
Old 02-02-2014, 02:07 AM
Deadeye64 Deadeye64 is offline
Deadeye64 is starting off with a positive reputation.
I'm really looking for an f250 but how difficult would the roof be to
Fix? Like how much am I looking at? The leak is what worried me- sweet
Truck though, I'd seriously consider it but would really lite to get the
cost of the roof fixed- in PA btw... Manhattan is three hours from where I am
I would plan towards the end of February to gave a look
If still avail.
Regards, Alec
Old 02-02-2014, 08:29 AM
LI250's Avatar
Go up to the 73-79 forum and search for roof rust or drip rail rust. How difficult it is depends on your skill set. If you can weld and do light fab work it's not too tough. If you can't it's still not to tough but probably not cheap. If there was no rust on the roof I would probably be listing it for $7500 and not 4800. I'm 25 minutes east of manhattan. I don't see it going anywhere anytime soon. I'm flexible on the price if you don't want the extra trim and stuff. That being said I'll bring it to my hunting land upstate before I let it go for less than $4k.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
2- Holley 600cfm Vac Secondary Electric Choke Carbs LI250 Ford Truck Parts for Sale 0 10-16-2013 08:02 AM
Shackle Flip Questions. Dont Flame me bro LI250 Offroad & 4x4 17 07-26-2013 01:34 PM
Tracbar Bracket LI250 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-12-2013 02:36 PM
Full shots of 2k13 f250 platinum nullop 1999 to 2016 Super Duty 25 02-04-2013 01:53 PM
Newest addition LI250 2011 & Newer Explorer 7 01-26-2013 09:09 AM
