Remote Oil Filter hoses need to be replaced, with or without tapped end for pressure sender?
Old 01-13-2014, 04:32 PM
John90's Avatar
John90
John90 is offline
Red face Remote Oil Filter hoses need to be replaced, with or without tapped end for pressure sender?
Hey,
I have the remote oil filter on my F150 and the common problem occurred
where the two hoses are leaking.
So I searched this forum, and found that the best thing to do, is to replace the whole assembly.
But neither RockAuto nor the dorman site tells me which part is the right one.
There is one assembly "with Tapped Hole for Pressure Sender at Engine End of Hose Assembly" and one without.
1998 5.4 4x4 XLT
Tow Package
Auto trans
As I'm living in Germany I can't ask a Ford dealer. Hope you guys do know which one to buy.
Thanks in advance! J.
Old 01-13-2014, 07:01 PM
2Fords1Jeep's Avatar
2Fords1Jeep
2Fords1Jeep is offline
If all you need are hoses, find a local shop that makes or repairs hydraulic lines. They should be able to help you out. They'll be better than the originals!
Old 01-14-2014, 03:59 AM
John90's Avatar
John90
John90 is offline
Hey thanks for the fast reply!
Yeah initially I wanted to to exactly that but after a bit of searching it seems that replacing just the hoses is an extremly annoying job and because I don't have much time right now and this truck is my DD I want to replace the whole thing...
It's either DORMAN Part # 625201 or DORMAN Part # 625202
Old 01-15-2014, 11:35 AM
dogman72's Avatar
dogman72
dogman72 is offline
On my 98 with the 4.6 I used the hose that was tapped. Hope you have a lift to change this hose, it's not fun. Engine side is not bad, but if you have rust on the frame rails it's tough... Good luck.
lovemyexpy
1997-2006 Expedition & Navigator
05-03-2011 09:30 PM
Steeler Fan 4 Life
01-28-2011 11:28 AM
great white
01-13-2009 01:48 PM
Chasjr1
Modular V8 (4.6L, 5.4L)
03-19-2008 10:31 PM
Freak4Ford
02-16-2006 05:47 PM
Quick Reply: Remote Oil Filter hoses need to be replaced, with or without tapped end for pressure sender?
