Gas tank & sender question
This bugger is pricey but I know I am going to run into a spot where I will need to buy one. Lets you use any sender with any guage.
Fuel Gauge Interface Module - Speedway Motors, America's Oldest Speed Shop
Another thing is if you are using aftermarket guages I have seen programable gas gauges for sale as well. I have to have a workng gas gauge, nothing else needs to work. Nobody likes walking for gas.
What engine are you running - carb or EFI flat head or ??? you may get more info if you give more detail. Just a thought.
Hey Tilley,
Hmmm.. We have a 12 volt system. We moved the gas tank out of the cab to get more room as we were tired of smelling/hearing it sitting beside us.
We went with the 22 gallon '70 Mustang tank (approx. $120 from Rock Auto) - 40% more range than stock.
We used the '70 Mustang sender that goes with that tank as it has the fuel pick up line built into it. We then soldered on a modern universal sending unit (0 - 200ohms) in place of the 0hm - 70 ohm one to talk to our modern fuel gauge.
You could do something similar but it does take (2) sending units - the '70 Mustang one for the fuel pick up & then the other that talks to your fuel gauge. Or you can go with the interface that matches the ohms from sending unit to gauge.
Good luck over there. We didn't work our's out ahead of time - It's much easier to sort this out during the construction phase (take it from me). Nice truck - this upgrade is worth the effort.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
reamer
03-09-2014 01:12 PM
73f250highboy
01-26-2012 06:00 PM
ml2jw4life
11-20-2009 03:02 PM
DAYUIZ
08-12-2004 02:20 AM
