helps to align door frame
Received 4,116 Likes
on
Like what was said about these trucks they were made for utility not for looks. I used doors from a pickup on my panel and the gaps were wider than the original doors. The assembly lines back then were manned by men/women not the computerized robots of today so things weren't quit as precise.
Sorry I don't have any pics, but what I did was beveled one edge of the 1/8"x3/8" flat bar so you can lay multiple spot welds on the outside of the door. The flat bar is placed in a manner to extend the width or height of the door. Grind the edge of the door to your desired gap. Hopefully my explaination makes sense.
DON'T adjust the door edge until the cab is bolted down to the frame with new mounts front and back. You'll be surprised how much the door opening will change. Looks like the cab needs to raise at the front mounts and lower at the rear mounts or pull down on opposite diagonals (depending on how the other door fits. Put a 1.5" block under the front mount and have someone stand or sit on the floor by the rear corner just to see how much it can move. If you adjust the door before you mount the cab you'll likely be sorry later.
Longh
10-09-2018 07:32 AM
NW 150
11-09-2017 01:37 PM
berry1234
15
08-18-2010 11:39 AM
