Any Difference in 2.3 Blocks
From a source, 75 through 88 blocks are interchangeable.
See the list here:
therangerstation.com
Specifically:
2.0/2.3/2.5L Family - The Ranger Station Forums
it is still available.
tom
See the list here:
Specifically:
tom
https://www.ford-trucks.com/forums/1...done-this.html
fixed it by adjusting the idle, run fine until i traded it off, still see it going around town
The main difference in blocks are: up to 87 have larger main journals, 95+ use oil pump driven directly off the timing belt.
Some early EFI blocks have the fuel pump hole covered with a bolt on plate, others didn't get the hole machined out. That would be the only item that *could* affect your plan.
4tl8ford
20
01-30-2014 10:36 AM
Midnight88
04-11-2008 05:26 PM
mswift
11-19-2006 07:49 AM
