what tranny can go in my bronco?
Hi I'm looking to put a 4 spd manual tranny into my 82 ford broncowith a 300 6, what my questions are is can I put a 4 spd from a f150 300 six 4x4 or af250 300 6 4x4? Only reason I'm asking is cuz a friend told me I couldn't because the drive shaft in the f series is longer, well I already have a driveshaft from my c6 would that work? I also need to replace one of the bolts in my engine mount, do I have to remove the whole mount or can I just take the bolts out and how should I go about lifting the weight of the engine off the mounts, thanks in advance
The New Process 435 was a factory option in the Bronco and 1/2-ton F-series for several years. It has one of the best service records and some of the most desirable gear ratios for these trucks.
Driveshaft length makes no difference. You can always have a driveshaft shortened or lengthened. (And you might need to change lengths because the manual transmissions, as a rule, are shorter than the automatics. This sometimes translates to needing to shorten the front shaft and lengthen the rear. The only other concerns in swapping transmissions is bellhousing bolt pattern, crossmember location and making certain you have a transmission for a 4x4 as the tail-housings are different between 2WD and 4WD units and with 4WD you need to be able to bolt the transfer case to it.
Now since you are talking about a swap from an automatic to a manual, you are going to need clutch pedal and linkage assemblies along with a flywheel and clutch for the engine in question. Fortunately, the 300, 302, and 351W all share the same bellhousing bolt pattern. They do, however, each have their own flywheel...its a balance issue. Your best course of action would be to find a donor truck with the transmission you want already in it and grab everything you can from it. (Hint: If you find an F-series with the transmission you want. grab the front driveshaft too because it WILL work).
As for lifting the engine off its mounts far enough to replace a bolt, an engine hoist and some care to avoid pinching hoses, wires etc and removing the fan shroud should yield enough leeway to lift the engine far enough to clear motor mount hardware.
If you can find a donor truck to get back the parts that you don't have, the project is as simple as pulling from one and installing in the other. (Someone actually removed a manual from a Bronco?)
Keep in mind though that if you go with either of the 5-speed manuals as Kem suggested, you will need to change to the hydraulic clutch setup rather than the mechanical that was OEM in your 82. Both the M5OD and the ZFS5-42 use the same hydraulic slave cylinder to actuate the clutch.
The only 4-speed OTHER than the NP435 available in the Bronco in the early-mid 80's was the Mexican-built Tremec 3-speed + overdrive. They aren't all that common but the top-loading derivative of the T&C OD (car platform unit used in the Granada, Fairmont, and a few others) that got dropped into the F-series, Bronco, and E-series vans is more commonly referred to as the "RTS" (truck version) built by the Tremec Corporation under the model name/number T-170. If you have one, you have one... thats about all there is to say about them. There are far better and more modern 4-speed manual transmissions that will work but as for the manual transmissions from the era, the RTS and the NP435 were it.
Just a little update I have found someone relaitivelyy close to me with everything I think I need for this swap for sale, here is what the situation is like right now.
He is parting out a 2wd 300 6 with a four speed tranny and a 4wd 300 6 with a 4 speed tranny.
The 300 6 with the 4wd has a bad engine but he said he would sell me the good engine that was running when parked from the 2wd and then the tranny, tcase, driveshafts, and the whole assembly from the 4wd 300 6 all in one package.
now I am not 100% sure but I think that all of this would work? am I right by saying that the 300 6 engine from the 2wd will bolt right up to the tranny and tcase off of the 4wd 300 6?
I was also thinking that maybe I would just be better off rebuilding the 300 6 I have and just getting the tranny and tcase and the entire assembly off the 4wd parts truck since the engine I would be buying will most likely need a rebuild anyways?
I appreciate any feedback, thanks
Volvo92906
09-12-2012 08:29 PM
rxfx101
08-11-2005 07:01 AM
1yamman350
10-15-2003 11:46 PM
Crazy Canuck
04-01-2003 08:58 AM
