fog lamp replacement - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 01-12-2014, 05:36 PM
jdm5630 jdm5630 is offline
jdm5630 is starting off with a positive reputation.
i have an 07 expedition. the fog lamp lenses have cracked and there is moisture inside the lenses. My question is can I replace the lenses only or do I have to buy the whole assembly?
Old 01-12-2014, 06:28 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Whole assembly.
Matt
Old 01-14-2014, 01:24 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
These are notorious for cracking. Heat from the lamps and brittle plastic lens.
Old 01-14-2014, 11:00 PM
You guys know of an aftermarket that will last longer?
Old 01-18-2014, 03:31 PM
dave91gt dave91gt is offline
dave91gt is gaining momentum as a positive member of FTE.dave91gt is gaining momentum as a positive member of FTE.
They are cheap on Ebay. I bought a set (cant remember the store) for my wifes 08 expy. They came complete, bulbs and all. Changed them out in 10 minutes. Looks much better. Had them 6 months and still look new.
Old 01-20-2014, 06:45 PM
berry1234's Avatar
Quote:
Are the lenses plastic or glass?
Old 01-22-2014, 11:06 PM
They are plastic.
LED replacement lamps for 2000 SD lebeter 1999 to 2016 Super Duty 1 07-08-2015 08:20 PM
OEM Fog Lamps for 05 F150 XLT Rudeman 2004 - 2008 F150 1 06-21-2015 01:12 AM
79 replace blinkers with fog lights quaallen Electrical Systems/Wiring 3 07-04-2014 05:30 PM
fog lamps dannyg1992 1999 to 2016 Super Duty 4 04-14-2014 06:43 AM
Want yellow fog lights, not clear Darth Baiter 1997-2006 Expedition & Navigator 9 04-19-2007 09:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
