2001 ranger 4.6 swap - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-12-2014, 04:54 PM
Allstar recovory Allstar recovory is offline
Allstar recovory is starting off with a positive reputation.
so i spend alot more time over in the diesel section. i have just aquired a 2001 ranger 2wd with a 4cyl that has alot of issues and i decided to pull it and replace with crown vic running grear. has any one done it with a 2v 4.6? i see one guy that did it with a 4 cam and alot of 5.0. i know it will be tight but it will fit. i will be using a v8 explorer radiator and v8 explore rearend
what do you guys think?
Old 01-13-2014, 09:44 AM
smalltrucker's Avatar
smalltrucker smalltrucker is offline
smalltrucker is starting off with a positive reputation.
I'd sure try and stay with the 5.0L to make things a whole lot easier. Sounds like you've done some searching, don't know of any 2 valve swaps done, all the DOHC versions. Quite a bit of fabrication required. Even with the 5.0L swap, things get harder with 2001 newer Rangers due to the wiring. Lots of documentation on what it takes for those. I can sure try and point you in the right direction if needed, some good write-ups. Just up here outside of Stevens Point.
Dave
http://www.cardomain.com/ride/2052265
Old 01-13-2014, 02:14 PM
In doing research I think I will be going with the 4 cam 4.6. I have come to that decision bc I really like that motor a lot more then the 2v and I can find one cheap out of a Lincoln mark viii. as for the 5.0 I have never liked that motor one bit, its crude and heavy and I never thought they made good power in stock form.
im no stranger to making thing fit where they should not go lol 4 years ago I put a 12 valve cummins in a 97 f-150 and everyone said that could not be done. it was not a bad swap and I would definitely do it again given the chance
Old 01-14-2014, 11:40 PM
Monteg0's Avatar
Monteg0 Monteg0 is offline
Monteg0 is starting off with a positive reputation.
Of course it can be done, but the 4.6/5.4 Modulars are just super wide. Are you wanting to drive this thing, or just doing it for fun? Major problems you'll run into are clearance for the heater box, steering, exhaust.
Old 01-14-2014, 11:42 PM
Monteg0's Avatar
I've never liked the 5.0 either, but a ranger doesn't weigh squat. and with all the time (and $) you'd save yourself, you could build it into something decent. Just my .02...
Old 01-16-2014, 03:23 PM
I will be driving it in the summer and leaving it parked most of the winter.
Old 01-16-2014, 10:17 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
The 4.6 is very wide, you might as well be trying to shoe-horn a 460 in there.
Find a 5.0 from a 86-94 Mustang GT or a Explorer and take the easy route.
Old 01-17-2014, 06:33 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
A 4v 4.6 is quite a bit larger than a 460.. good luck shoehorning that thing in there.
The Explorer motor is a solid 300-325hp with a simple cam change, you have the option of using carb or EFI induction, and you have several manual and automatic transmissions to chose from in 2wd and 4wd.
Old 01-17-2014, 08:16 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
I think 01 was the last of the 5liter in the explorers... Or was that 2000
Either way, the ranger and explorer were darn close to the same engine bay. Check wiring diagrams and the harness may plug right in.
As far as the 4v fitting or not fitting, the Lincoln aviator I think was a rebadged explorer, with a dohc 4.6...... And if a ranger is the same engine bay as explorer.....
But I'd swap in whatever motor came in an 01 explorer, be it a 5liter or 4.6 because it will probably bolt right in.
I hate to suggest it, but check out "theranger station. Com". Lots of good info there
Old 01-17-2014, 09:04 PM
Monteg0's Avatar
By the time they had introduced the 4.6, they had changed the explorer. the engine bay was made larger, so the 4.6 would fit. TRS is a good site for the tech articles, i believe someone did a fairly detailed write up about the difficulties in a 4.6 swap.
Old 01-17-2014, 11:00 PM
UNTAMND's Avatar
I just looked it up and I was correct, last explorer with 5 liter was 01....
Meaning the 5 liter will bolt in, and wiring harness will plug right in.
Boom! Engine swap done.
With a cam swap like suggested and headers, the thing would be a blast to drive.
Research torquemonster headers. That will give you an understanding of how super restrictive the stock manifolds/tubular manifolds really are.
Here's a pic
Old 01-18-2014, 12:27 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
You might want to re-consider the Explorer rear-end also. The spring perch for the Ranger is on top and the Explorer has it on the bottom.
Old 01-18-2014, 01:33 PM
Quote:
That's well documented as well as the 4.6 swap at TRS. Guys with the early Mustangs are using the Explorer rear end.
Dave
Old 01-20-2014, 04:34 PM
kanuck15's Avatar
kanuck15 kanuck15 is offline
kanuck15 is starting off with a positive reputation.
Count me in for the "use a 5.0" group
Considering ive got a 98 ranger with a 5.0 its all the truck you need. I left the 5.0 in stock explorer form and it will still break the tires free coming into 2nd gear. Plus I did my swap in a weekend. Pulled it in the garage after work friday, 3.0/trans out that night. 5.0/4r70w in the next day, spent sunday plumbing and wiring then drove it to work monday (on open down tubes).
Either way whatever route you go I wanna stay tuned in. If its a 4.6 I am really curious about it. If its a 5.0 I still like seeing them
Old 01-26-2014, 12:24 AM
Ok so the 4 cam 4.6 is at home in the garage. I think all the extra work will Be worh it. I just really don't like the 5.0 and besides that everyone is doing 5.0 swaps. I will keep everyone posted as well as i can
ford explorer 101 83sd Explorer, Sport Trac, Mountaineer & Aviator 2 06-08-2016 10:12 PM
03 explorer engine swap Serge Jacob Engine Swaps 3 11-17-2015 06:53 PM
Looking at possibly purchasing an 06-09 Explorer looking for advice/opinions turnkyle Explorer, Sport Trac, Mountaineer & Aviator 7 12-01-2014 02:44 PM
2001 Ranger 3.0 to 4.6 Swap aaron318 Engine Swaps 12 02-11-2014 07:27 AM
Anyone swapped a Explorer V8 into a ranger? NJohnstonMN Ranger & B-Series 9 01-11-2011 12:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
