Correct OEM Ford SD Rubber Floor Mats?
on
My 2014 F350XL 4x4 CC has the depressed upper left floorboard on the drivers side or as some people would say has no foot rest/dead pedal. I ordered The OEM Ford rubber SD floor mats from a dealer and received the mats that look like they are made for a truck with a foot rest/dead pedal and don't have the depressed area molded in like in the Ford OEM Accessories photo and are just a flat mat.
The Ford # on the box I received is DC3Z-2613300-A and it is a flat mat with no recessed pocket. BC3Z-2613300-AA is an older number that is superseded by the number above but it may have the recessed molded pocket but not sure.
Does anyone have any insight into this?
Thanks.
Thanks.
Thanks.
Thanks.
In my research, I came across 2 different styles of mats. I believe this is the one you would need,
http://www.ebay.com/itm/2012-2013-FORD-F250-F350-SUPER-DUTY-ALL-WEATHER-FLOOR-MATS-CREW-CAB-FORD-OEM-/290794857805?pt=Motors_Car_Truck_Parts_Accessories&hash=item43b4b9654d&vxp=mtr
I actually bought the Husky Weather Beater Mats because they offered more coverage than the OEM style. The OEM ones are cut out around the footrest, as I am sure you are well aware of, and incorporates the rubber footpad, footrest, semantics, as part of the coverage of the driver's side mat, if you will.
The Husky Mats cover the entire floor on both sides, from the front seat floor supports, to the bottom of the fire wall, to the door sill, and to the console. And they have 2 spaces or bumps for the grommets. The rear covers door sill to door sill(one piece) and from under seat storage to the front seat supports.
IMHO, they are softer, traps liquid from spilling onto the carpet, and offer way more floor coverage and protection. They are cut out for a perfect fit for out trucks. I was actually impressed with how well they cut these for a custom fit. Only difference is that they do not have 'Super Duty' on them, and they are priced more than the OEM Style.
on
Thanks for the input. The dealer that I bought the mats from is going to check into this on Monday. The photo you supplied is the mat that will fit my floor board shape yet the mat I received is cut out for the foot rest. Maybe Ford forgot that they still use the depressed floor board on the 2014 XL vs a foot rest on the XTL or higher models? I'll keep you guys posted when I get the answer from the dealer.
Good Luck!
Thanks.
Thanks.
It has color options too.
