Horse Power and Gear Ratio's
For the gear ratio there is a tag bolted on with the diff cover. The first 3 digits in the bottom row are the ratio, the next 2 should be 88 which means 8.8" ford axle. If it has limited slip there will be a L in place of the decimal point like this 3L55. The first digit is partialy covered by a bolt most of the time. You can also post the axle code from the drivers door jamb decal.
gary534
10-20-2005 12:32 PM
1978Crew
09-03-2004 01:16 AM
