Looking to swap my M5OD-R2 for a ZF S5-42
The ol' Mazda M5OD-R2 is starting to go and is in need of rebuild/replacement. I'd like to have something a little more stout for hauling as I have a lawn business and do quite a bit of it and hear that the ZF's have the best of both worlds with granny-like 1st's and decent highway ratios.
Bolting up to a 1993 4.9L 300-6 2wd SWB. First of all...is it even an option to begin with? Do ZF's use Concentric slave cylinders? What other modifications would I be looking at? Is it worth it? I'm really just trying to explore my options here. Anyone who can give me some insight or advice into this would be considered awesome.
Thanks in Advance,
M_Jennings
Thanks in Advance,
M_Jennings
Small block ZFs used concentric slave cylinders. You should only need a new driveshaft to swap Mazda to ZF in 2wd. The driveshaft needs some type of slip feature, because the ZF has a fixed output yoke whereas the Mazda has a slip-yoke. I think that a two-piece driveshaft is the most common way to do this, but it will most likely be a custom piece.
With the rarity of F250HD/F350s with 5.8s to begin with, and then ones with manuals, and then ones parting out or for sale cheap. I think your odds are very low of finding a cost effective small block ZF that doesn't also need a rebuild to swap in.
Sure look for one, you might get lucky, but I suggest you just put more thought into getting a more suitable truck.
sufferingant
25
05-17-2011 02:31 PM
oscar4pbr
08-01-2010 08:17 PM
TXKaiser
03-22-2007 11:15 PM
bigred69
10-12-2005 11:18 AM
jlboers
07-08-2004 11:17 AM
