1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
99 exp electrical?
Old 01-11-2014, 09:47 PM
fe8u's Avatar
fe8u
fe8u is offline
99 exp electrical?
So we have a 99 exp Eddie Bauer Auto 4wd. When the switch is on 4wd not auto it will kick out of 4wd and the dash will get all screwed up, mph all over the place. The 4wd switch does not work. turn the vehicle off, back on a couple times and it will right it self. Could it be the speed sensors on the transfer case, 4wd module? Other? Any ideas will be nice Thanks Chad
Old 01-12-2014, 12:19 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Based on the conditions you've described, I would think the 4WD module is the problem.
Old 01-12-2014, 10:31 AM
fe8u's Avatar
fe8u
fe8u is offline
would it be located on the passenger kick plate area thanks
Old 01-12-2014, 12:05 PM
alloro's Avatar
alloro
alloro is offline
It's behind the right side of the instrument panel.
Keep in mind that the GEM is the actual brains for the A4WD system, but the 4WD module is actually just a relay pack. But when any of the relays act up, it doesn't matter what the GEM is telling them to do, so this is why you'll want to start at the 4WD relay pack module.
See the attached PDF for an image of the location.
File Type: pdf
Dante827
1999 to 2016 Super Duty
11-14-2016 08:26 AM
dcaddi2
07-25-2011 05:35 PM
agcntry
1983 - 2012 Ranger & B-Series
07-05-2008 08:46 PM
beckel
10-28-2004 02:38 PM
Quick Reply: 99 exp electrical?
