Mike build 59 f100.
Old 05-15-2014, 10:00 PM
mcali2's Avatar
mcali2
mcali2 is offline
added new shock mounts, sanded a few dents out of the top part of the cab. and i got in my new disk brake kit.
  #107
Old 05-16-2014, 03:25 PM
mcali2's Avatar
mcali2
mcali2 is offline
I have spent the day sanding and painting the cab, it looks great. I may need another coat of paint for some areas as the primer is thin ans sanded through with 400 grit. I am not ready to put color on it so I may start with the doors and or fenders. Picks soon.
  #108
Old 05-17-2014, 07:34 AM
jenkinsj's Avatar
jenkinsj
jenkinsj is offline
disk brakes
Where did you get the kit for the disk brakes? What do you plan on using for your power booster?
  #109
Old 05-17-2014, 03:29 PM
mcali2's Avatar
mcali2
mcali2 is offline
It came from speedway. For 279.$ shipping was 7$ for the day.
I will use the kit from cpp.
  #110
Old 05-17-2014, 09:02 PM
jenkinsj's Avatar
jenkinsj
jenkinsj is offline
Speedway is about 30 miles from me. thanks for the info. Is that where your going to get your wiring kit?
  #111
Old 05-18-2014, 10:37 AM
mcali2's Avatar
mcali2
mcali2 is offline
I will get a hot rod wire kit from ezwire. I believe is the name.
  #112
Old 05-18-2014, 09:52 PM
2losteve's Avatar
2losteve
2losteve is offline
In the photo of your shock mount I couldn't help but notice what looks like an added filler/plug on the center of the diff. housing. Have you checked it out?
Steve
  #113
Old 05-18-2014, 10:31 PM
mcali2's Avatar
mcali2
mcali2 is offline
Steve
Yes it was added by the origional owner. I kept it as it looks easier to fill with.
  #114
Old 05-19-2014, 07:39 PM
mcali2's Avatar
mcali2
mcali2 is offline
I have been sanding and painting and as I get the all the small timgs looking i keep finding smaller things. When will it end !!!!! LOL I had the door ready but there was something bothering me. the edge of the door that gets hit with you open the door looked out of shape slightly. I hammered that mack in shape and now I need to add a little body filler. I think after this last adjustment the door will be as good as I can do it. I will mount it and give the body and door one last sand with 400g spray it white and move on to the other door. I will paint the blue or green when I have all the other body panels on the truck so I get a straight line. at least that is the plan. I may change my mind.
  #115
Old 05-23-2014, 10:43 PM
mcali2's Avatar
mcali2
mcali2 is offline
I found some seats. from a early bronco. In green like the color paint I was thinking of.
  #116
Old 05-24-2014, 12:39 PM
jenkinsj's Avatar
jenkinsj
jenkinsj is offline
Where did you get you shock mounts? I need upper and lower front and back.
  #117
Old 05-24-2014, 04:47 PM
mcali2's Avatar
mcali2
mcali2 is offline
I found the rears on e bay. I have one extra rear bottom mount.
  #118
Old 05-24-2014, 05:04 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Why does that sound dirty?
  #119
Old 05-24-2014, 05:07 PM
Maltman's Avatar
Maltman
Maltman is offline
^^^^ hahaa
  #120
Old 05-24-2014, 07:10 PM
spurredon's Avatar
spurredon
spurredon is offline
Probably because the parts haven't been degreased yet!
Quick Reply: Mike build 59 f100.
