Mike build 59 f100.
#32
Just to name a few ---arm rests,radio,sun visors-both sides,white steering wheel with horn ring,magic air heater,door locks-bothsides,chrome grill and custom script on doors and chrome windshield trim,and last but not least big back window.And that's just what I see from a glance! Oh yea almost forgot two tone paint.Original owner went all in on this one and it looks like most of the options have survived with the truck.That is a pretty rare thing. I'm sure I missed some and others can point them out. You got a real keeper there.
#35
I pulled the front end apart tonight. Getting the king pin out was fun. I had to use heat to loosen up the old crude grease up. I will be using a disk kit up front and need to know do I need to keep the backing plates for that kit? anyone use the kit on e bay? I'm going disk all the way. I was given a running f350 to pull the engine ,trans and anything else i want off it. It as a 460 and a 4 speed in it. I hope it will all fit.
#38
Awesome. Thanks. I am thinking of adding a duel turbo setup to the engine. I have built them before That would allow my to get power without buying heads and other expensive parts. just run 5 or 6 lbs boost. At lease its a idea. I'm sending my front beam off for lowering. i wounder how much that engine will drop my truck due tot he extra weight.
#39
#41
#42
I pulled my rear end apart. everything looks fine as far as i can tell but now i need to figure out how to put it back together correctly. I don't have the tools and the manual does not tell you how to do the backlash and stuff. I guess I should have left it alone and just changed the seals. It was too cold to do much on the body. My body is sore from all the work yesterday.
#43
#44
