1962 F600, New Wiper Motor & Switch, Parks in Middle of windshield? - Ford Truck Enthusiasts Forums
Old 01-11-2014, 07:30 PM
michaelshewkin michaelshewkin is offline
michaelshewkin is starting off with a positive reputation.
Just installed a NEW 2-Speed Wiper Motor, Pivots, Linkage, Arms an Blades and they park in the Middle of the windshield?
On the back of the Motor appears to be a white plastic cam adjustment with a 3/8" Hex Nut Molded on it coming out of the cover. Is this an adjustment for the Park Switch?
I would like for them to park at the base of the windshield and thought someone might know how to adjust the park position on the NEW motor.
Checked Manual but didn't see anything on how to do this?
Any Ideas?
Old 01-11-2014, 10:59 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Are the "new" parts genuine Ford? Did the truck come with two speed wipers originally?
The wiper arms (that retain the blades) have to be installed on the pivots in a specific location in order to get them to park correctly.
Put 'em in the wrong place, the arc is different and when turned off, won't go to the base of the windshield.
Old 01-11-2014, 11:11 PM
Genuine ford wiper motor, yes had 2 speed wiper motor and switch.
New motor - has what may be an adjustable park switch cam as the old one did not.
I will try to see if by loosening the cover, I can turn it. It has arrows on the cover showing it will turn.....will see and let you know.
It parks dead center of windshield or in the very middle of full arc range....??
Old 01-11-2014, 11:24 PM
When you installed the arms on the pivots, did you do it at the base of the windshield?
There is no part number for a park switch on truck wiper motors, but there is one for the cars.
Old 01-12-2014, 12:57 AM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
I would pop the arms off, watch the pivots as they cycle...mark at the approx park location with a felt tip marker..if the sweep is correct..readjust the arms on the pivots..also, was the transmission pivot linkage installed exactly as removed...if its 180 off...Im pretty sure that would screw up the sweep pattern.
- cs65
Old 01-12-2014, 09:29 AM
CHANGED TRANSMISSION (SHORT) ARM 180 DEGREES
Quote:
- cs65
Thanks for the response!......I did try and changed the short transmission arm on the motor shaft and flipped it 180 degrees with no change. The new Ford NOS Motor parks perfectly in the middle of the arc of travel....
I first put the new wiper arms on at the base of the windshield and then when I wend to turn them on the motor being in the middle of the arc of motion tried to drive the arms in to the cowl and inside the cab.....
I believe even though this motor is the right part number, it looks like the park position is adjustable on the outside by loosening the cover screws and using a 3/8" wrench on the white plastic (molded) cam which positions the park switch? (I hope this will work) and then tighten down the cover screws locking in the new position.
I will try to get a picture of this and post....
Old 01-12-2014, 07:25 PM
Quote:
Originally Posted by michaelshewkin View Post
I believe even though this motor is the right part number...
C1TZ-17508-D .. Bosch Two Speed Electric Wiper Motor (Motorcraft WM-139) / Obsolete
1961/63 F100/950 & T700/950 / 1963 N500/950 & NT850.
Old 01-13-2014, 06:32 PM
1962 Ford F600 New Wiper Parks in Center of Windshield?
Well, after checking into this issue again, I pulled out the new motor and looked at the Ford/Motorcraft Box and compared numbers. They didn't match. So I went back to bench check my old 2-speed motor and it checked fine.
Removed the NEW Motor and Re-installed the OLD Motor and all works fine. Old motor is a little noisy, but works just fine. OLD Pivots and Linkage Bushings were the culprit in sloppy wiper arm travel.
I will try to post the numbers I have as I have (2) brand new NOS Motors that I don't know exactly what their application is for? They are both (2) Speed Bosch Motors.
I will see if Bill (Number Dummy) the Ford Expert can help me identify them?
I got some extra experience in removing and replacing the Wiper Motor....LOL.
Thanks to all for there help, the other tips help me set the park position to be perfect!
Old 01-13-2014, 10:03 PM
The number marked on the wiper motor is an ID engineering number, not a part number.
C1TZ-17508-D marked C1TF-17504-B or C1TF-17504-C or C2TF-17B571-J or C6TF-17B571-F
No intermittent wipers- wipers will not park after using washer?? No cost fix!! phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 50 11-18-2016 11:22 PM
Wipers an switch problem WW2N 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-26-2016 09:11 PM
Why do wipers not park right after new wiper motor? 1998Ranger25L153CID Ranger & B-Series 8 04-26-2016 06:50 AM
Wiper motor swap problems Hellonwheels 1987 - 1996 F150 & Larger F-Series Trucks 2 02-19-2014 08:18 PM
Electric Wipers Sore Knuckles 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 11-02-2006 02:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
