duraspark ll swap
duraspark ll swap
i am doing the duraspark ll swap and was wondering why the colors of the wires on the new module and distributor dont match any wire diagrams. on my module left to right i have white red purple orange black green, do i just wire in order like diagram? ford 300 inline 6. thanks for your help, i think it is a 1980 module.
The Duraspark coil uses a large C shaped plastic connector.
Most call it the 'horseshoe connector'
You can get one from an autoparts store, Dorman #85848.
Dorman/Ignition Coil Connector (85848) | AutoZone.com
The green wire goes to the Duraspark module.
The red wire should have a 1.2 ohm 20W resistor in line from hot in 'run' and no resistor in 'start'
There's a nice color coded diagram here;
Duraspark II
Duraspark II
Wishonski
01-23-2011 09:19 AM
l00py1211
15
08-17-2006 04:00 PM
