ESOF testing: strange results - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-11-2014, 05:53 PM
SDSC4X4 SDSC4X4 is offline
SDSC4X4 is starting off with a positive reputation.
Truck is an '01 V 10/automatic.
Hubs stay engaged all the time. I've checked the hubs and lines to them with a vacuum pump (including the line to the HVAC controls), all hold vacuum indefinitely.
When I "tee" a vacuum gauge into the line going from the hub lock vacuum pulse solenoid to the hubs, I show full engine vacuum (about 16" hg) going to the hubs at all times, regardless of the dash selector switch position. (Engine running)
I also am getting 12 Volts on the center pin of the connector to the hub lock vacuum pulse relay. The schematic I've found (http://www.ford-trucks.com/forums/97...esof-help.html) shows this should be 5 Volts (VREF). Other systems powered by the VREF seem to be working fine....
I've searched many threads here, and have not seen any reference to these test results
The transfer switch shifts normally from each mode to next. All fuses are good and the ESOF relays check out fine. I replaced the vacuum hub lock solenoid in August with a new Motorcraft unit from Ford.
So, my questions: where is the 12 V coming from? Where is the 5 V (VREF) sourced? Would this voltage damage the hub lock vacuum pulse solenoid? Why the constant vacuum? In other words, I've about worn out my "bang head here sign," how do I fix this one (!) ???
ESOF questions scld1354 1999 to 2016 Super Duty 14 01-23-2016 05:48 PM
esof g tinsley 6.0L Power Stroke Diesel 13 03-19-2015 07:28 PM
ESOF Pulse Vacuum Hublock Solenoid? SDSC4X4 1999 to 2016 Super Duty 15 12-21-2014 08:30 PM
4x4 and ESOF problems BWPowersmoker02 1999 - 2003 7.3L Power Stroke Diesel 22 06-20-2012 09:28 AM
vents not working, vacuum questions LSO1123 1999 - 2003 7.3L Power Stroke Diesel 4 11-14-2011 06:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
