Intermittent Wiper Switch Brand
Yesterday, in some bad rain, my intermittent wiper switch decided to stop and start (not the way it should), The wipers would swing up, stop for 10-30 seconds, then continue. Wiggling the shaft in the switch helped keep them going more, which tells me the switch needs to be replaced. The interval setting works, its like the switch is kicking on and off so it doesn't tell the governor box/module to move the wipers.The timing intervals/ speed was right, it was just they wouldn't move without hanging up. I replaced the module last year with a known good one, disassembled it and checked all the solder joints, which were good. It did this on the interval settings and high/ low as well.
This pertains to an 87-91, the 92 and newer uses a multifunction switch.
I'd just thought I'd see if any of these brands were good already know motorcraft is good, but just thought I'd check to see if any of these were for a lower price.
Napa- Echlin
BWD
Oreilly's- MasterPro
AZ- Duralast/Wells
Any feedback or info is very appreciated
Napa- Echlin
BWD
AZ- Duralast/Wells
75highboy390
29
07-14-2013 10:27 PM
baverwolf
10-02-2011 09:29 PM
FordPickup460
24
12-04-2004 02:18 PM
