Unibody cab/bed strength - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 01-11-2014, 05:25 PM
biggut's Avatar
biggut biggut is offline
biggut is starting off with a positive reputation.
I want to do a frame-off on my 63 unibody shortbed. Is the cab/bed assembly strong enough to be bolted to a rotisserie without any problems? I'm not sure I'll use a rotisserie-but; it'll need to be at least strong enough to be moved and man-handled while it is off the frame. I've never even been around a unibody before-let alone work on one. They're exceedingly rare out here in farm country. The farmers stayed away from them; as they used their pickups just like their 2-ton trucks-hauling lots of big loads.
Anyway, if anybody out there has seen a unibody mounted on a rotisserie; I'd love to hear how it worked. Thanks, Brett
Old 01-15-2014, 03:52 PM
cobraguy cobraguy is offline
cobraguy is starting off with a positive reputation.
I had mine off and had some big casters that fit the holes for the front cab mounts and used a floorjack at the rear valance. It then sat on jackstands for awhile before I lost my shop and the truck went away. When I got rid of the body I filled it with 4,000lbs of scrap and dragged it onto a rollback tow truck and it didn't buckle.
Old 01-15-2014, 04:48 PM
biggut's Avatar
That's awesome! I guess I can probably lift mine up off the frame without damaging it then. The casters/floor jack seems like a good idea. I may look into doing something similar. Thanks for the info and the idea. Brett
Old 01-20-2014, 08:36 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Here is some i made from an old shower sales rack.
Used a central floor jack to maneuver it around the garage.
Garbz
Old 02-03-2014, 10:05 AM
Guni Guni is offline
Guni is starting off with a positive reputation.
Guni
I put unis on wirly gig all the time. The rotis I use is capable of being pulled down the road at moderate road speeds and I have done that. Normally I put rtis on car trailer to haul any distance and that also works great. Body strength has never been a problem. Problem is to be sure connection points are well reinforced or strong locations already. I use tailgate holes on rear and hood hinge holes on front.
The rotis (Wirlygig) I use has a third pipe that will stiffen and help any time you might want to make major body alterations that decrease strength.
rotisserie/used parts Dukeshire 1961 - 1963 F100 Unibody 1 09-29-2016 10:38 AM
Rotisserie for F-100 cab jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 07-22-2011 09:49 AM
Anyone make a rotisserie out of engine stands? Got pix? black58 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 12-17-2009 01:47 PM
1961 unibody rotisserie ymurf 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-10-2006 02:31 AM
Rotisserie Fabrication tl1965 1961 - 1966 F-100 & Larger F-Series Trucks 5 01-06-2002 06:14 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
