timing on propane engine - Ford Truck Enthusiasts Forums
Old 01-10-2014, 08:49 PM
joey2fords's Avatar
joey2fords joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.
i have a 1994 f250 351w c6 on propane only. previous owner had dual fuel then decided to go with straight propane; removed both gas tanks. i don't know what else, if anything was removed.
i need to get this truck through emissions testing and so i am giving it new : cap, rotor, plugs, wires, air filter, and oil change.
my question is : what should the timing be set at for this engine to run on propane ? i am not even sure if it has a spout connector on this year but, if it does, should it be disconnected ?
the truck actually runs fine (except for an up-and-down idle during warm-up only) but it's due for the tune-up anyway.
Old 01-12-2014, 12:42 AM
21411 21411 is offline
21411 is starting off with a positive reputation.
you will get better and more in general response in the gasser section. Diesels use propane like you would use nitrous. Try the alt fuels section under gas performance I believe. Smart guys over there too!
Old 01-13-2014, 07:28 PM
joey2fords's Avatar
ok, after reading the title of this forum more closely that makes sense . thanks.
Old 02-07-2014, 07:18 PM
tempforce's Avatar
tempforce tempforce is offline
tempforce is starting off with a positive reputation.
usually propane powered engines timing is set a few degrees early... if you can find a local propane distributer. that sells or knows a installer. they will be able to give you the correct settings.
if you ever need to remove the heads, have them shaved or do it right ... install high compression pistons and rods... 12:1 would be a good place to set the engine up for, as propane has 105+ octane....
the higher compression will give you more power and mileage...
Old 04-14-2014, 01:06 AM
The FNG's Avatar
The FNG The FNG is offline
The FNG is starting off with a positive reputation.
I have a 1990 f-250 with a 351w and e4od and bi-fuel propane system. There is a nameplate under the hood that calls for 10*BTDC, which is the same as stock if I remember correctly.
Bullydog Propane Tank jonnybronco Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 03-07-2014 12:27 AM
1990 460 propane issue 460jared96 1987 - 1996 F150 & Larger F-Series Trucks 5 01-16-2014 01:04 PM
74 F-350 460 Propane questions Fireslayer Fuel Injection, Carburetion & Fuel System 4 08-29-2013 01:19 PM
propane conversion. TaborCT 1967 - 1972 F-100 & Larger F-Series Trucks 15 09-03-2011 08:04 AM
Timing for a 460 on propane? WarriorWithin 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-03-2011 02:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
