What headers for a 351 - Ford Truck Enthusiasts Forums
Old 01-10-2014, 08:27 PM
ohbrian ohbrian is offline
ohbrian is starting off with a positive reputation.
I have a 56 with a 351 cleveland about to go back in. I was wondering if anyone is running headers other than sanderson? I'm having a hard time finding all the measurements to determine if they will fit in there without issues.
Old 01-13-2014, 03:16 PM
bra$$monkey's Avatar
bra$$monkey bra$$monkey is offline
bra$$monkey is starting off with a positive reputation.
nope - good ol' cast iron on mine.
I want to change them out because all the non-car people I show off to say - "it's all rusty" - drives me crazy - shiny crazy custom made up truck & all they see is the darn cast iron header
Old 01-14-2014, 09:26 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Quote:
Keep us posted on what you end up doing. I'm thinking about changing my cast iron manifold out too.
Old 01-14-2014, 03:16 PM
dale waddle dale waddle is offline
dale waddle is starting off with a positive reputation.
351c headers
I used 71 mustang mach 1 headers on my 54 f100. they fit fairly tight to the block but were not hard to install. I have transdapt motor mounts and had to grind 1/8 " off them to clear the bottom tubes. I also had to cut a 1/4" notch in the passenger side header exhaust extension flange to clear the transmission oil pan.they are also close to the frame mount brake master cylinder and power brake unit. I used hedman s-bend style universal exhaust extension - they make it much easier to line up your pipes. I would recommend using header wrap on at least the lower pipes to keep heat off the brake unit, the starter, and transmission pan.
dale
Old 01-14-2014, 04:10 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Before you toss out the iron mani's, try coating them with this. Brush it on and let it bake in. Works good, looks good.
Eastwood Silver High Temperature Exhaust Coating Paint Kit : Amazon.com : Automotive Eastwood Silver High Temperature Exhaust Coating Paint Kit : Amazon.com : Automotive
Old 01-14-2014, 04:34 PM
Quote:
dale
I bought a pair of 351C 4 barrel headers at a swap meet but haven't tried to install them. Their pretty banged up and they were cheap but the seller didn't know who made them. Thought I might be able to make them work when the time comes.
Old 01-14-2014, 08:14 PM
DGMFORD's Avatar
DGMFORD DGMFORD is offline
DGMFORD is gaining momentum as a positive member of FTE.DGMFORD is gaining momentum as a positive member of FTE.
I have a 1986 351w in mine, and was not successful on headers, I'm using the Toyota PS kit and on the drivers side, not much room with that gear box.
Old 01-14-2014, 09:34 PM
Thanks guys!
Old 01-15-2014, 02:54 AM
Mervy49's Avatar
Mervy49 Mervy49 is offline
Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.
I installed Sanderson's huggers on my 351w and it was really tight with the Toyota box. I have the engine dead center in the frame and there's not much clearance on either side but they do work.
Old 01-15-2014, 05:20 AM
Aarons54f100's Avatar
Aarons54f100 Aarons54f100 is offline
Aarons54f100 is gaining momentum as a positive member of FTE.Aarons54f100 is gaining momentum as a positive member of FTE.
I run dougs shorties on mine.
Old 01-17-2014, 09:52 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
But do not use the wifes oven to bake them . Trust me on this one !!!! Her's was new , I bought it for her ,so I figured some rights to use it were came with it . WRONG!!!
Old 01-18-2014, 08:38 AM
48 Steel's Avatar
48 Steel 48 Steel is online now
48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold
Also running Sandersons. I had them coated with Chromex High temp.
_________________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"If it don't go, chrome it"
will 302 headers bolt to 351w heads ColtonMullis Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 24 06-06-2016 09:39 PM
351W long tube headers? Bluebandit! 1961 - 1966 F-100 & Larger F-Series Trucks 7 01-10-2016 09:17 PM
Headers LIQUID8 1967 - 1972 F-100 & Larger F-Series Trucks 27 05-26-2015 08:06 PM
351w Fender Well Headers? 80ford100 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 01-15-2015 06:35 AM
351w...header fitment Gigemags05 1947 and Older Ford Trucks 0 12-08-2014 02:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
