windshield leaks
Old 01-10-2014, 03:44 PM
Lost Yankee's Avatar
Lost Yankee
Lost Yankee is offline
windshield leaks
ok guys I have been told that the EX has a problem with the windshield leaking on the drivers side, and it does, so does replacing the windshield fix this? Or is it something else that requires 50lbs of silicone
Old 01-10-2014, 04:06 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
A lot of times the bigger issue is once you remove the windshield their is rust under it that needs to be taken care of, I think once they replace the windshield it should be sealed..
Old 01-10-2014, 08:25 PM
Forest's Avatar
Forest
Forest is offline
On my 2003, I had a drip from passenger side top when raining hard. Took it to windshield shop. They were able to remove and re-do the seal at only about $50. Did not leak again. No rust detected in that case...
Old 01-11-2014, 05:04 AM
Lost Yankee
Thanks guys sounds good !
Old 01-12-2014, 12:21 AM
wallz's Avatar
wallz
wallz is offline
A lot of times it can be resealed, but if you have a cracked windshield your better off just replacing it. That way they can check for rust at the same time.
Hard to see if there is any rust with out removal, but it can be done.
Either way, any good glass shop should be able to take care of it for you.
Old 01-12-2014, 12:22 AM
Forest's Avatar
Forest
Forest is offline
Whether replacing the w/s or not, I think the only way to seal the leak is to remove the w/s and re-do the sealant. At least, that is the way I remember it being done.
Old 01-12-2014, 12:27 AM
wallz's Avatar
wallz
wallz is offline
I have resealed plenty of leaking ones over the years, but I am a glass technician, so I would see more than the average guy would.
Old 01-13-2014, 01:45 AM
Fordsdad's Avatar
Fordsdad
Fordsdad is offline
If there is surface rust issues; remove and re-install is the way to go. Re-sealing would only prolong the issue. If your not sure and you want to keep it for a while, don't bother with the re-seal. If the windshield has not been replaced recently and the leak has started; chances are it's not related to a poor install but, rather a surface rust issue. I speak also as a auto glass tech.
Clem's Cousin
10-25-2014 06:46 AM
HB_BD
1999 to 2016 Super Duty
10-28-2010 10:19 PM
Stevelknievel
10-03-2010 11:18 PM
iwals
09-27-2010 12:44 PM
fp_5
42
05-04-2005 09:13 PM
Quick Reply: windshield leaks
