1968 4 speed manual.
Okay, don't take me for a fool but I removed the top and shift lever from a 1968 F-250 4 speed manual trans. so I could clean and paint the engine and engine compartment. Now I can not get it back into neutral when I reinstall the cover. Anyone know what I might be doing wrong? Is there a sure fire trick to resolve this?
Thanks,
Bob B.
Thanks,
Bob B.
navy time
My first 3 years were on the Iwo Jima LPH2, We made 2 deployments June to April 66-67 then October to July 67-68. I ended up on the LST January to August 69, doing spring to late summer out of Vung Tau doing riverine support . I was an Engineman 2nd classs. Those engine room watches were noisy. I get $250. a month from the VA. I had enough after 4 years.
New Process 435 shift lever retainer cap (B8T-7220-D) has two notches, is retained by two pins that protrude from the tower.
This cap must be pressed down and held down while turning it to remove it.
People unaware use pliers to remove the cap which tears out one or both of the notches. Not Pleasant!
on
If you have the gears locked up from trying to find neutral. Then you'll have too get them back into the neural slots. You may have to try turning the drive shaft to find neutral.'
Plus you may have to jack up the right rear or both rear wheels if it have posi or locker in the rear end. When drive line is free and will turn tranny is in neutral. Like Kenny said make sure the shift cover is in neutral also. Put a new gasket on or use RTV...
orich
orich
Nylon Teeth?
I've worked on Chev and Ford small blocks from 70s-80s wasn't aware they used plastic that early. This is something I didn't do. The truck only shows 72,000 miles and I believe that to be accurate. I bought it to resell so I don't think I'm going back to that. I will do it in place if needed. See how it runs.
I've been distracted by other things here lately and just about to get back to it.
Thanks for the input. I will keep it in mind for next time.
JP_E350
04-13-2016 05:56 PM
Otis 54
10-05-2009 07:25 AM
