F-600 Questions - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F-600 Questions
Old 01-10-2014, 02:47 PM
Fossilman Ford Fossilman Ford is offline
Fossilman Ford is starting off with a positive reputation.
F-600 Questions
Hello All!
I'm currently looking at a 1993 F-600 4x4 that I might purchase, remove the flatbed that's currently on it and put on a dump bed. It has one of the Ford straight six diesels (there's a bunch of snow on the fiberglass hood and have been unable to roll it forward to identify the engine) and an Allison 4-speed automatic with a column shifter. What I'm wanting to know is if with this transmission, if the F-600 could haul a backhoe on a tandem axle, dual wheel trailer?
If more info is needed, I can certainly do some more digging, or in this case, snow removal.
THANKS!
Old 01-10-2014, 11:04 PM
gandrimp gandrimp is offline
gandrimp is gaining momentum as a positive member of FTE.
I use my 96 f800 with a 5 speed Allison, which should be that mine has a lower low gear.
Old 01-12-2014, 01:58 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
A 93 could be the last of the 6.6/7.8 litre Fords, or a Cummins 5.9. Likely it is 210hp or less, being a 4X4. The allison could be an AT545, or MT643.
A VIN # would help, I'm sure.
Old 01-13-2014, 02:00 PM
Quote:
Looks like I didn't finish a thought (wife says I do that a lot). I Tow with mine, 7500 lb trailer, and not uncommon to have equipment in the 20,000 lb range, so 27,500 lb and Im not sure what the truck weighs.
If your use to the pickup Allison, these are a lot different.
nevrenufhp, I finally got my 8.3 running good. Boost hose was worn through and the racor fuel filter was letting air in around the pump. Then I took the top off the p7100, its good now.
Old 01-13-2014, 09:18 PM
nevrenufhp's Avatar
Great!
How do you like it now?
Old 01-13-2014, 10:13 PM
Quote:
Originally Posted by nevrenufhp View Post
Great!
Its getting used to me . I'm liking it, but its a different kind of power.
Old 01-13-2014, 11:46 PM
nevrenufhp's Avatar
Now for some Marine 480 injectors, a #0 fuel plate, gov springs, a little timing advance, head studs, and an HT3B turbo under the original.
Old 01-14-2014, 06:58 PM
SO! The snow has melted enough out west here and so I rolled back the hood on the truck and to my surprise (and ultimately, my dismay) it has the 160HP 359 CI Cummins (the 5.9L).
This now spurs another question... would it be worth the time and ultimately the money to dump in a 270HP Ford 474 CI Diesel (the 7.8L)?
Your thoughts much appreciated!!
by-the-way, the VIN is 1FDWK64C9RVA24045
thanks again
Old 01-14-2014, 07:41 PM
nevrenufhp's Avatar
No way on the swap to a 474, keep the 5.9. Hop it up, just a little(free mods). With 250hp, it'll do really well. I'd say, up to about 40k pounds. Now, the trans is probably going to be the turd of an AT545, and 250hp is the max you want to send thru it.
Old 01-21-2014, 10:21 AM
I realized after I posted my last comment that I wasn't thinking at all. First, the 474 and its little brother are good engines but very hard to find parts for it. When it comes to modifying & tweeking the engine's performance the Fords are a bit of a lemon. Where as the 359 Cummins has all sorts of performance parts available and it's still being produced.
Sorry! I didn't know what I was saying. I would keep the Cummins and build it up.
Thanks for the help.
Old 01-21-2014, 09:05 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Fossilman Ford View Post
1993 F-600 4X4 / VIN: 1FDWK64C9RVA24045
Welcome to FTE
1FD = FoMoCo USA - Ford Truck (Incomplete Vehicle).
W = GVWR Class 6: 19,501-26,000 lbs.
K64 = F600 Diesel.
C (1993/99) = 5.9L (359 cid) Cummins model FD-1060 I-6 diesel.
9 = Check digit, FoMoCo use only.
R = 1994.
V = Kentucky Truck Assembly Plant.
A24045 = 1994 Numerical Sequence of Assembly.
Old 04-19-2014, 12:31 AM
R = 1994.
The door column tag said the truck was built in October of 1993 which I guess is technically Model Year 1994, hence VIN code "R" = 1994
Old 04-19-2014, 04:53 AM
R = 1994.
The door column tag said the truck was built in October of 1993 which I guess is technically Model Year 1994, hence VIN code "R" = 1994.
Production Date: 10/93 = 1994.
Since new vehicles are introduced in September of the previous year, production begins in August.
Old 05-30-2014, 01:36 PM
Did the "heavier" F-Series (F-600 & up) have the option for the 8.3L Cummins?
Old 05-31-2014, 09:16 PM
nevrenufhp's Avatar
Yes, they sure did. From mid 93 & up.
302 built for torque? hail destroyer 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-21-2016 06:08 PM
a $29,000 snow plow? !!! four-sixty-power 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-25-2016 10:26 AM
Front range snow plow options. imcqueen Colorado Chapter 8 12-01-2015 03:22 PM
EGR/Vacuum Delete Help wintertruck87 1987 - 1996 F150 & Larger F-Series Trucks 2 11-16-2014 09:52 PM
Snow Plowing? Caleb H General Automotive Discussion 22 12-18-2011 08:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
