F-600 Questions - Page 2 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F-600 Questions
Old 06-03-2014, 11:05 AM
wagners wagners is offline
wagners is starting off with a positive reputation.
I just purchased a 1992 F600 Crew Cab with the 6.6 and automatic Allison Transmission. I want to make a pick up out of it so I need to shorten the wheelbase and get the back drive shaft cut down. Has anyone done this before and could offer some advice?
The VIN is 1FDNK62P2NVA21354 if anyone has a decoder it would be nice to see what it originally came with versus what is there now. I will post more pics as we go, we just picked up a 1992 dually bed so now it is time to get the frame and drive shaft attended to.
Old 06-03-2014, 01:02 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
It's done all the time.
If the frame rails are straight and the same size front to back, you can simply redrill the frame and move the rear suspension forward.
What type of suspension does it have? Spring or air?
Spring suspensions offer a punishing ride for what you are doing.
As for the drive shaft, once you have a final dimension, you can take that to a driveline shop to have it rewelded, balanced etc. Again, not something you can do at home unless home is a machine shop with a lathe and high powered welding equipment.
If you have to cut the frame, again, higher powered welding equipment (not a 110v Harbor Freight wire welder....) is required, along with proper welding techniques and reinforcing.
Not a job to learn on imo.
Old 06-03-2014, 01:42 PM
gandrimp gandrimp is offline
gandrimp is gaining momentum as a positive member of FTE.
Quote:
I will agree with everything 85e150six4mtod posted except the quoted above it should read " Spring suspensions offer a PUNISHING ride for what you are doing."
Old 06-03-2014, 09:52 PM
I agree with the punishing ride but I should have my 36ft fifthwheel or 36ft goosneck attached a lot of the time. I took it out for a spin with the enclosed 36ft goosneck and it felt pretty good.
I am assuming from that, that 1500 to 2000 lb pin weight will smooth out the ride. What I have decided after mounting the 8 ft bed I have is too have the front of another bed welded to it. I have 30 inches to the cab after the 8 ft bed is placed so I plan on leaving a 2 inch gap for flex and butt welding the front section of another bed to it.
I say I, but I mean my friend who does body work. So I will have an 8ft dually bed with a 28 inch extension that will provide a nice place to bring up my stacks and provide a nice place for chains binders and misc stuff, while keeping the side view looking like a long bed dually.
I have to raise the bed 5 inches off the frame to get the body lines right so I plan on welding 5x2x48 3/16 tube steel across the frame then mount the bed to that structure. My existing goosneck plate will have to be rasied 7 1/2 inches so that plate will stick through the bed.
What I have to figure out is how to securely mount that 7 1/2 inches above the frame and make it adjustable so my gooseneck ball and my fifth wheel hitch can be rasied or lowered de pending on the trailer I have hooked to it. I have already had all the axles flipped on my trailers because my 1 ton is a 4x4 with 20 inch wheels and everything was to short to clear the bed rails.
I think I will mock it all up with wood and go pull under the fifth wheel and goosneck. then decide which I want more, the body lines to match up or if I want to haul my trailers.
Any ideas or drawings of existing hitch hook ups would be appreciated.
Old 06-03-2014, 10:28 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
You may have lucked out with that one. 92 is when the famous P-pump started showing up on the 6.6/7.8s.
Old 06-03-2014, 10:42 PM
What is that and where do I look?
Old 06-04-2014, 01:24 AM
nevrenufhp's Avatar
It's the injector pump that made the Cummins 5.9 famous in 94-98 Dodges. The 2 pumps it can be are an MW-pump, or a P-pump. Sure fire way to tell is the numbers on the pump. It starts with PES6, then the next will be the model(MW or P). Either pump has some hot rodding potential.
Old 06-05-2014, 02:19 PM
Fossilman Ford Fossilman Ford is offline
Fossilman Ford is starting off with a positive reputation.
Awesome truck Wagners
I ultimately want to exchange the regular cab on the F-600 I'm trying to obtain and replace it with a crew cab.
Here are some pictures of the truck...
Old 06-05-2014, 02:33 PM
The front of the Beast! I would cut off the snowplow mount
Driver-front hub
the water tank would also go
Stamped VIN tag
total mileage 28,672.8
Info plate about 4x4 equipment
transfer case tag
Old 06-27-2014, 03:05 PM
Anyone know what the transmission code "AA" mean? And the axle code "AG" mean?
Old 08-23-2014, 12:10 PM
DFitzhunter DFitzhunter is offline
DFitzhunter is starting off with a positive reputation.
Best oil for 7.3 F-600 engine
What is the best oil for a 7.3 1989 F-600 Engine. In central Florida, extreme heat conditions, truck is driven very little but sometimes on long runs.
Old 08-23-2014, 12:56 PM
nevrenufhp's Avatar
Quote:
7.3 in an F600? As in a gasser 429? I thought they had either a 429 V8 gas, or 6.6 or 7.8 inline six diesel.
Either engine, I'd say regular ol Shell Rotella 15W40.
  #28
Old 08-28-2014, 01:41 AM
wantahertzdonut's Avatar
wantahertzdonut wantahertzdonut is offline
wantahertzdonut is starting off with a positive reputation.
Quote:
Originally Posted by Fossilman Ford View Post
~snipped photos of 4x4 awesomeness~
I have to ask, what kind of fuel mileage does one get in a monster like that? I see these come up for sale once in a while and I'm dying to know!
302 built for torque? hail destroyer 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-21-2016 06:08 PM
a $29,000 snow plow? !!! four-sixty-power 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-25-2016 10:26 AM
Front range snow plow options. imcqueen Colorado Chapter 8 12-01-2015 03:22 PM
EGR/Vacuum Delete Help wintertruck87 1987 - 1996 F150 & Larger F-Series Trucks 2 11-16-2014 09:52 PM
Snow Plowing? Caleb H General Automotive Discussion 22 12-18-2011 08:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
