Front Wheel Hub Assembly...Help Please
I have a 2007 5.4 F150 Lariat 2wd that needs a new wheel hub assembly, but everyone i find is for a 4wd.... Can someone please help me find the part i need for my truck? If you check out the link you will see the only hub assemblies are for 4x4s
07 2007 Ford F150 Wheel Hub Assembly - Driveshaft & Axle - Centric, First Equipment Quality, Motorcraft, National, PartsMaster, Pronto, SKF, Timken, Front - PartsGeek
Do you have the two piece rotor and hub? If so:
Rock Auto also carries them...
Do you have the two piece rotor and hub? If so: Amazon.com: Centric 124.65902 Disc Brake Hub: Automotive
I honestly dont know if it is a two piece...i would like to order the correct part and get a few installation quotes from some mechanics...it's hard to trust mechanics...im done getting screwed...
ok so regardless of what my truck has this part should work, correct?
first one from the top ----> 07 2007 Ford F150 Disc Brake Hub - Brake - Centric, Motorcraft, Front - PartsGeek
ok update.... i went to the mechanic that will be doing the work for me and he said all i need are the rotors which contain the bearings... thanks again for the help guys... good thing i didnt order the hub
94GreenTruck
08-12-2014 07:58 PM
