My 1978 F250 2WD Distillery Truck...
Hey guys, I recently got a 1978 F250 as my new daily driver/grain hauler for my distillery! Always been in love with these trucks, and thanks to the wealth of info available here, I was able to track down the right one, only about 20 minutes away.
Anyway, a little about it... built in the Mahwah Ford plant, it's got the 351M(with a mild cam and oddly a race style dual oil filter setup - perhaps for better oil pressure?), 4spd T18 transmission, 3.31 Dana 61(it's a 2WD), and is largely stock. The guy who had it bought it as a delivery vehicle for his stove shop, and took meticulously good care of it - I've got the original purchase invoice, and nearly every receipt for work done on it! The thing is in wonderful shape too, although it needs some exhaust work, and a bit of tuning on the new carb.
My plans for it are to keep it mostly stock, with some upgrades for functionality. I'm going to redo the interior in tan, upgrade the lights(H4 bulb conversion and Hella 700FFs), do the Dakota Digital drop in gauge cluster, ditch the T18 for a T19(if anybody has a bead on a close ratio T19 please let me know!), and put on some Cragar soft 8s to replace the current wheels. As it will be on the road almost all the time, not going to do a lift, though I'd also like to figure out some way to level out the front - the suspension is tired, but I'm not sure if new struts and springs will do it, or if the Autofab 3" kit might be the ticket? Also going to be putting in either the MSD Atomic or EZ EFI system - REALLY excited for that!
Anyhow, I'll keep my modification/restoration progress updated, but thanks again to all of you for sharing your knowledge and experience.
The front suspension isn't completely gone, but judging by sloppy damping characteristics, it could really use a refresh - even if just new struts and springs.
Just so you know these tucks don't have struts. They have standard shocks front and rear. Coil springs in the front and parallel leaf springs in the rear. Typically speaking as long as the shocks aren't leaking and they pass the traditional "bounce" test they are fine. That is push down on the truck and as long as it settles out (stops bouncing) in 1-2 bounces they are fine. The springs on the 250 and 350 trucks are pretty stiff. And can give a firm ride especially when empty. Worn springs can cause excessive cupping and in severe cases severe flat spots on the tires. Especially in the front with the coils. Worn leaf spring will sag and or cause the truck to lean if broken. You just might want to double check and verify so don't spend unnecessary money on parts that may not be bad. I hope I don't offend you by posting this, just trying to help.
Yeah, id go along with your idea regarding replacing those wheels with something else! Its really nice seeing the distilling industry follow the wine and microbrewery segments! small, craft producers making a product for the local market! best of luck, and thats a good looking truck!
DAAAYYYUUMMMMM that looks good!!
Really, really!! Looks Really good, enjoy it and get used to all the attention you will now get!!
