shift indicator cable 1991 ford truck - Ford Truck Enthusiasts Forums
Old 01-09-2014, 06:05 PM
Frank Murch Frank Murch is offline
Frank Murch is starting off with a positive reputation.
I broke the shift indicator cable on my 1991 ford F Superduty. Does anybody know where I can buy a replacement and how much work is involved to change out the broken one for a new one?
Thanks
Old 01-09-2014, 06:24 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
here is one on ebay.
http://www.ebay.com/itm/1987-88-89-90-91-Ford-truck-Bronco-shift-indicator-W-OD-F150-F250-F350-/380812761564?pt=Motors_Car_Truck_Parts_Accessories&hash=item58aa3599dc&vxp=mtr
Old 01-10-2014, 01:18 PM
mrrish79's Avatar
mrrish79 mrrish79 is offline
mrrish79 is starting off with a positive reputation.
I did it on my 97 F250 and wasn't hard at all. Pulled one from a same style F150 at a junk yard and had it installed in less than an hour. Best thing was that it only cost me a few bucks!
Old 01-10-2014, 01:44 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
You gotta pull the instrument cluster out and the assy. is held in there by 2 screws. It comes out the bottom. The cable is attached to the column by one screw.
Old 01-10-2014, 02:39 PM
boonslick boonslick is offline
boonslick is gaining momentum as a positive member of FTE.
Shift Indicator
Quote:
Thanks
Hello and good afternoon.
I had to buy mine at the Ford Dealer.
You have to remove the trim surrounding the Cluster and, if I remember correctly, pull the speedometer.
As I recall you do not have to remove the Instrument Cluster just the clear cover. Also, you have to remove the steering column cover, put the shift lever in low to do this.
On a good note: you can adjust the cable so it is "dead on" the gears and no more half in, half out.
Take care.
Boon
P.S. Once you get started you will see that it is not that hard. On my 87 I just needed a phillips screwdriver and a torx #12.
hyper shifting lyndalynda 1987 - 1996 F150 & Larger F-Series Trucks 9 03-04-2016 05:27 PM
shift indicator problem for a 91 ford f250 with automatic Snacky 1987 - 1996 F150 & Larger F-Series Trucks 0 03-22-2015 08:52 AM
Throttle cable replacement eatont9999 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 24 08-20-2011 01:07 PM
problem with ford exploer taz1y Explorer, Sport Trac, Mountaineer & Aviator 5 02-23-2007 08:07 PM
Shift Indicator cable blueovalboy86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-07-2005 09:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
