HELP! No oil in oil filter housing. - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-09-2014, 12:15 PM
binhtran binhtran is offline
binhtran is starting off with a positive reputation.
I need help i am working on a 2008 Ford f250 6.4
The truck came to me with a bad turbo so i replaced it after replacing them i found that it had 2 bad injectors so i went and replaced those. Now i ran the truck takes a little longer to crank but it does start then i noticed that the oil filter cap was a Napa cap and I've heard about those giving people problems i had an old oem cap laying around so i went and replace that with a motorcraft filter. went and run the truck for a bit remove the oil cap no oil came up AT ALL...
Im guessing thats how the turbo and injector went out. I need help to see if it's could be the LPOP OR HPOP problem or something else. Thanks!
Old 01-09-2014, 12:47 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
injectors are not fired by a hpop. They are controlled by the pcm. There is a high pressure fuel pump that feeds them.
Better take a look at the filter and the cap and the spring inside. there should be a pool of oil in the bowl.
I am moving this to the 6.4 forum for more comments/suggestions.
Old 01-09-2014, 03:05 PM
GHeTTo JOe's Avatar
GHeTTo JOe GHeTTo JOe is offline
GHeTTo JOe is starting off with a positive reputation.
if the oil filter cap was not oem was the filter also not oem? if not i would make sure it is replaced with one.
Old 01-09-2014, 03:08 PM
Quote:
i did replace the cap and filter with oem still not getting any oil i believe the oil lines going to the turbos arent getting oil as wel
Old 01-09-2014, 03:12 PM
senix's Avatar
I would look further into oil housing and oil bypass valve.
Old 01-09-2014, 03:32 PM
Old 01-09-2014, 03:40 PM
GHeTTo JOe's Avatar
is that a extra O ring in the filter housing? is it possible the filter cap with its O ring is not seating fully?
Old 01-09-2014, 03:59 PM
just checked its not an extra O ring.
Old 01-09-2014, 05:16 PM
senix's Avatar
So when you remove the oem cap and the filter pops up there is no oil at all? It will drain back down once the lid is removed.
65 psi is the the pressure at the oil regulator. Perhaps it is bad. I would put a pressure gage on the truck and see what you are pushing.
Oil feeds the turbos from the filter.
Old 01-09-2014, 06:59 PM
Yes when I remove the cap no oil at all filter looks brand new
Old 01-09-2014, 07:06 PM
senix's Avatar
Codes, check engine light at all. This maybe a problem with the regulator. I'd look into it.
Old 01-09-2014, 11:39 PM
GHeTTo JOe's Avatar
oil pressure regulator looks easy and cheap to replace on the front of the engine. i did come across some issues of needle bearings failing from the lifters. the bearings can end up in the oil pump and cause damage.
http://www.ford-trucks.com/forums/10...come-from.html
powerstroke help has a nice video that was linked in the first page of that thread.
<table class="ADVV1-HotlineArchives-Whites" cellpadding="0" cellspacing="0"><tbody><tr><td class="ADVV1-HotlineArchives-LeftRuledRows">Customer Concern: </td> <td class="ADVV1-HotlineArchives-RuledRows"> The engine had a squealing noise, then it began to knock. Small needle bearings were found in the oil.
</td></tr></tbody></table>
<table class="ADVV1-HotlineArchives-Whites" cellpadding="0" cellspacing="0"><tbody><tr><td class="ADVV1-HotlineArchives-LeftRuledRows">Tests/Procedures: </td> <td class="ADVV1-HotlineArchives-RuledRows"> 1. These needle bearings are likely coming from the valve tappets (lifters). The lifters have a roller on the bottom and the needle bearings can come apart from them and get into the oil. In most cases, when these fail, they get into the oil pump and do heavy internal engine damage. Usually, it is a better idea to replace the motor for this concern rather than try to repair it.
Old 01-10-2014, 10:49 AM
do you guys know where the oil pressure regulator is exactly?
Old 01-10-2014, 11:17 AM
senix's Avatar
Front of the motor, drives side beside the oil pan/front cover.
Old 01-10-2014, 12:32 PM
replace the oil pressure regulator started the truck it runs still no oil coming up.
Oil cap is not interchageble with the HFCM. I had problems any ideas? HowDoIfixIt 6.0L Power Stroke Diesel 2 04-26-2015 10:21 PM
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 10:47 AM
1994 7.3L IDI TURBO FUEL RETURN LINE ? kjjr20 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-18-2014 05:16 PM
Finalizing maintenance and modifcation list before starting next project the_auto_tech 6.0L Power Stroke Diesel 43 10-13-2013 10:33 PM
Oem Oil filter houseing cap? milfpig115 6.0L Power Stroke Diesel 4 09-17-2010 06:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
