HELP! No oil in oil filter housing.
I am afraid there is more going here then just a driveway fix. Put a true oil pressure guage on it is one idea.
Oil pump is on the front of the motor. Perhaps an issue. Clogged pickup tube maybe.
Do you have a code reader? Perhaps a code is also stored that may give a clue.
I might even suggest pulling the oil filter housing and seeing if you can determine anything.
oil is full im not sure what kind of oil it is.
