HELP! No oil in oil filter housing. - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Old 01-11-2014, 07:44 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I am afraid there is more going here then just a driveway fix. Put a true oil pressure guage on it is one idea.
Oil pump is on the front of the motor. Perhaps an issue. Clogged pickup tube maybe.
Do you have a code reader? Perhaps a code is also stored that may give a clue.
I might even suggest pulling the oil filter housing and seeing if you can determine anything.
Old 01-11-2014, 12:28 PM
PSDx3 PSDx3 is offline
PSDx3 is starting off with a positive reputation.
What is the oil level on the dipstick? What kind of oil is in it?
Old 01-13-2014, 11:28 AM
binhtran binhtran is offline
binhtran is starting off with a positive reputation.
no codes but the owner of the truck did tell me when he do his oil changes he does not always change his filter he would change his filters every 2-3 times he changes his oil
Quote:
oil is full im not sure what kind of oil it is.
Old 01-13-2014, 02:51 PM
senix's Avatar
This is obviously is a lack of maintance and owner awareness. And now you get to fix it. This is sounding more and more like a rebuild or a crate motor needed.
Old 01-13-2014, 03:33 PM
what i found the inner part has marks all around it
Old 01-13-2014, 08:49 PM
GHeTTo JOe's Avatar
GHeTTo JOe GHeTTo JOe is offline
GHeTTo JOe is starting off with a positive reputation.
so did you find any metal that caused that? does not look like needle bearing carnage from other pictures i have seen. so is your plan to put in a new geroter
oil pump and see what it does?
Old 01-13-2014, 08:53 PM
senix's Avatar
I think I would be looking in the pan at the pick up screen as well.
Old 01-16-2014, 03:18 PM
well guys i got the problem fixed. I went ahead and changed out oil pump i drop the oil pan check the screen/pick up line seems to be ok i did blow air thru where the line goes to see if anything was clogged put it back together and oil is now flowing. Thanks for the help guys
Old 01-16-2014, 03:52 PM
senix's Avatar
Thanks for reporting back. Glad you got it fixed.
Most likey it was oil starvation from an improper filter and lack of maintance as well.
Old 01-18-2014, 12:35 PM
Good Job Binhtran! If you had taken it to a Ford Dealer they would have rebuilt the motor for you to fix the problem. Hope that is the only part damaged, but, time will tell.
Oil cap is not interchageble with the HFCM. I had problems any ideas? HowDoIfixIt 6.0L Power Stroke Diesel 2 04-26-2015 10:21 PM
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 10:47 AM
1994 7.3L IDI TURBO FUEL RETURN LINE ? kjjr20 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-18-2014 05:16 PM
Finalizing maintenance and modifcation list before starting next project the_auto_tech 6.0L Power Stroke Diesel 43 10-13-2013 10:33 PM
Oem Oil filter houseing cap? milfpig115 6.0L Power Stroke Diesel 4 09-17-2010 06:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
