'04 6.0 Recurring Start Failure
#196
Sweet Thanks Cheezit
Heres the other DTC you are referring to
Crankshaft Position Sensor (CKP) Monitor Operation:
DTCs P0336 - Crankshaft Position Sensor A Circuit Range/ Performance
P2617 – Crankshaft Position Output Circuit/ Open
Monitor execution Continuous (8ms)
Monitor Sequence None
Sensors OK Not applicable
Typical Monitoring Duration Continuous
Crankshaft Position Sensor Malfunction Entry Conditions:
P0336 – 500 rpm< Engine Speed (N) < 4500 rpm
P2617 – 90 rpm < Engine Speed (N)
Crankshaft Position Sensor Malfunction Thresholds:
P0336 – Powertrain Control Module monitors the Crankshaft Position Sensor (CKP) sensor signal for a
unique valid pattern used to indicate piston position. Checks for the absence of the CKP signal. (Crank Mode
– 5 errors, Run Mode – 10 errors).
P2617 - Counter increments in Fuel Injector Control Module when the input CKP is absent and increments
when engine is out of sync with the Camshaft Position Signal (CMP). (Crank Mode – 5 errors, Run Mode –
10 errors).
10 errors).
#200
I have a fluke 95 if he wants to use it.
I think he is like me and needs a new harness. I know I need one,I just wrapped every part of mine in tape that I could get to until I have a extra $450.
Anyone want to trade a spartan tuner for a harness
#201
#206
https://www.ford-trucks.com/forums/1...p-circuit.html
I know it says fuel pump , but this shows the wiring from the PCM aswell , Cheezit the numbers listed are these fuse links in the PCM or wire harness?
page 3, #85, f2 22 ,f2 36, f2 116, f2 105, seem like the older trucks had them but not sure about our 6.0s Thanks.
#208
Hey Thanks for Going over this with me
I did Not realize the FICM would Count Faults Too and throw a DTC for CMP & CKP sync Faults
So we Learned something or at least I did!!
Your the Man Thanks Moe!!
#210
Hi guys, sorry for the silence. You were starting to lose me there with all that Greek and Latin, but I have know doubt you guys know what you're talking about, and it's all relevant to my troubles. I figured I'd stay out of the way until our next step took shape It appears that the below quote is where I'm heading next, is that right?
I just got home late last nite from driving up from Phoenix, but enroute I was having to make arrangements to travel today to Dallas to attend a funeral. The son of one of my best friends passed away a few days ago from complications from diabetes. Tragic story, I need to be there. I hope to be back Friday noonish and would have all Friday afternoon and Saturday morning to work with the truck, before back to Phoenix for another trip. I will be following this thread in the meantime, and can respond if needed, so please, carry on. I'd love to have a firm gameplan when I get back, but we'll have to keep it relatively simple. I wouldn't know a 'dual channel scope' from a screwdriver, but I can be coached......Thanx for all the efforts......
