1963 Unibody Vin Decode Help - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 01-08-2014, 02:21 PM
63unibodydriver 63unibodydriver is offline
63unibodydriver is starting off with a positive reputation.
Looking for help to decode the numbers on this 63 i just picked up..
The guy i bought it from told me that it was a numbers matching truck. So i wanted to see if this claim was correct.
Here is the door data plate info:
F10CK 39 3100
114 T F100 668 A12
5000 135 3800 75
Not sure where to look on the frame and motor to check the other numbers....so any help would be appreciated!
thanks!!
Old 01-08-2014, 02:24 PM
post number 2
Old 01-08-2014, 02:25 PM
says i have to have 5.....
before ....
Old 01-08-2014, 02:26 PM
i can.....
have other functions....
Old 01-08-2014, 02:29 PM
10 days....before pm ability??
Old 01-08-2014, 02:38 PM
this is a 292 with a 3 on the tree
Old 01-09-2014, 01:19 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
F10CK393100 / 114 T F100 66B A12 5000 135 3800 75
Don't waste your time looking!
No such thing as numbers matching, cuz that's a GM thing.
You also posted the VIN/codes in the 1961/66 F100/350 Registry thread, I decoded it there.
Old 01-09-2014, 10:42 AM
The fellow I bought it from said he had paid some company to verify that it was a "numbers matching truck".....So is that statement incorrect?...a big fat lie?
The numbers on the frame do not correspond to the door data tag??...other than the equipment that it is calling for..?
Thanks for any enlightenment!
Old 01-09-2014, 11:17 AM
The fellow I bought it from said he had paid some company to verify that it was a "numbers matching truck."
Uh huh. What company could verify 'numbers matching' since there's no such thing? And...FoMoCo THREW AWAY all the records that pertain to these trucks decades ago!
Now, if you had a Cobra, that would be numbers matching, cuz 'ol Shel stamped VIN's on multiple parts.
The numbers on the frame do not correspond to the Warranty Plate??...other than the equipment that it is calling for..?
Compare the 'VIN' on the Warranty Plate to the VIN on the registration, to the hidden frame VIN to see if they all match.
VIN on Warranty Plate is referred to as the "Warranty Number." FoMoCo says it's not for title or registration purposes (it's too EZ to change)...but most people are unaware.
1963/79: Warranty Plate located on the left door face below the latch. People replaced damaged left doors with used doors.
99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
Since FoMoCo THREW AWAY all the records, there's no way to find out how these 1961/66 trucks were originally equipped.
Old 01-09-2014, 05:49 PM
Well....don't know much about "number matching" ..this is the first vehicle i have purchased with such a story attached....
Title number matches the door tag on the drivers side....not sure where to look on this truck to check the frame number.......whereabouts??...still has the ugly beige color on the hood though.....
New Member - 63 Ranchero identification carpediem Ranchero & 1961 - 1967 Econoline 6 02-19-2017 08:35 PM
Decoding Warranty plate and serial number 1960 F-100 Custom Cab Pacecar1986 1957 - 1960 F100 & Larger F-Series Trucks 5 01-02-2017 06:56 PM
number decode Schickel 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-23-2014 11:45 AM
decoding 1980 ford f250 vin blainechad 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-02-2013 02:41 PM
door tag decode 63 dump 1961 - 1966 F-100 & Larger F-Series Trucks 5 03-25-2011 04:12 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
