1949 F1 project - Ford Truck Enthusiasts Forums
1949 F1 project
Old 01-08-2014, 02:01 PM
slocop slocop is offline
slocop is starting off with a positive reputation.
1949 F1 project
So.. this F1 was owned by my dad in the early 70s. He used it as a ranch truck for years and then sold it to a friend. The truck was inherited by the friends son and relocated to Oregon. Somewhere along the line it received an engine transplant to a big block buick. About six months ago my dad ran into the truck again and ended up buying it back. It now lives in my barn as we restomod it back to life.
Old 01-08-2014, 02:12 PM
Big block blues
This big block Buick runs but is not what I am looking for. Since the original motor is long gone I think a fuel injected small block would work really nice in there!
Old 01-08-2014, 02:29 PM
Is this bumper factory?
Anybody familiar with this back bumper?? It sure looks factory. The contour and inner fender bumper support/attachment point make me think it was an option. Also, the truck has metal bed instead of the wood and slats.
Old 01-08-2014, 02:57 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is online now
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Metal bed was standard on a 49. I think the bumper is what is referred to as a ranch bumper? See them quite often on here, not factory. Very nice truck and should make a good project.
Old 01-08-2014, 03:57 PM
jthesby jthesby is offline
jthesby is starting off with a positive reputation.
Welcome! Looks like a pretty good start. Wish the one I'm working on was a complete when we purchased it.
Old 01-08-2014, 04:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Welcome! Boy, I'd be tempted to just preserve the exterior as-is, it has "the look". EFI and an SBC would be a lot of work, and you'd need to upgrade a lot of other systems to match the speed you'd be capable of. The easiest modern swap is a 283 two-barrel, you can buy adapters to the stock trans (which is what? or did they put a Buick trans in it too?). Gives a nice boost in power but won't break anything unless you're really trying.
Old 01-08-2014, 05:17 PM
DougofMontana's Avatar
DougofMontana DougofMontana is offline
DougofMontana is starting off with a positive reputation.
Slocop, welcome to FTE! If you look under the truck bed I think you'll find a wooden bed hid under that metal. I have '49 F1 that had that metal bed floor. Apparently that's how they left the factory in 49. The truck looks great! I started my '49 build in August and am almost down to the frame. Enjoy it! Great history of the truck.
Old 01-08-2014, 05:51 PM
gregstith's Avatar
gregstith gregstith is offline
gregstith is gaining momentum as a positive member of FTE.gregstith is gaining momentum as a positive member of FTE.
I know a lot of people want shiny paint and that's what I'm doing with mine because I had to strip everything to do such extensive repair but your truck looks awesome. I really have learned to appreciate the patina on older vehicles.
As far as fuel injection, I would give a thumbs up there. I put a 4.6 DOHC in mine. Hoping to get it on the road in the near future. I'm so tired of fiddling with carbs, but I know some feel totally opposite. To each his own, that's what makes this hobby so awesome. Good luck and welcome aboard.
Old 01-08-2014, 06:22 PM
das54's Avatar
das54 das54 is offline
das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.
Welcome to the best forum ever. You have a very cool project going. Too bad there are several very nice paths to choose from. I personally like the modern drive train under an OEM patina skin. The EFI engine with an electric pump in a 22 gal Mustang tank located between the frame rails behind the rear axle. I would have gone with a Explorer 8.8 limited slip rear if my truck hadn't already had a 9 inch. Mine will be getting a limited slip unit installed, hopefully soon. It's almost dangerous trying to get through an intersection when it's raining. Good luck and let us know now and then how your're coming along.
Old 01-08-2014, 06:45 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
A really nice looking truck with a great family history. Good luck with it!
Old 01-08-2014, 07:46 PM
Quote:
Unfortunately the trans matches the Buick and must go. I have an interesting donor car and story to go with it that I will post at a later date.
Old 01-08-2014, 07:48 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Welcome Slocop! It is always great to have a truck that has a connection to your family history. While you have engine/tranny decisions, the bones of the truck look great. Be sure to enjoy the journey of your project.
Happy Motoring!
DW
Old 01-08-2014, 07:51 PM
Quote:
"Had" that metal floor? Where you able to cut it out and use/replace the wood below or did you lay new wood over the metal?
Old 01-08-2014, 07:52 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Quote:
If this is the case, the original crossmember is likely already been removed, or modded. That said, wouldn't be too bad to drop in a carbed 302 and T5 for driveablilty. Just my 2 cents.
Old 01-08-2014, 07:57 PM
I cut the metal away and pulled the wood, as it was rotted on the places the metal was rusted. I suppose the proper way would have been to use a spot weld drill bit and drill out the 784 (approx. ) spot welds that hold that metal in, but I gave up after weld #35 and got out the air chisel. Was careful around the wheel wells and had the metal off in about 10 minutes.
My plan is to put a nice white oak bed in with polished stainless rub rails.
Vintage Picture Thread. (WARNING: 56K ~ Picture Loadin' Death!) 76f350spercamprspeal 1973 - 1979 F-100 & Larger F-Series Trucks 97 04-03-2016 11:16 PM
48' F1 PROGRESS BUILD !! cashy52 1948 - 1956 F1, F100 & Larger F-Series Trucks 45 09-07-2015 10:35 AM
Bad Habit all dressed up for a night on the town bad_habit_F350 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-09-2014 05:20 AM
Build Thread: 1993 f150 restoration project npd23 1987 - 1996 F150 & Larger F-Series Trucks 17 01-15-2013 09:25 PM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 09:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
