Power Steering pump recommendations on a 302 with IFS
I have a 52 F-1 with IFS, rack & pinion P/S, 302 Ford & Chev. alternator.
Need some suggestions for pump, reservoir etc.
I don't have any mounting brackets, pulleys, etc. now.
I see the GM pumps with reservoir listed in Speedway. Would this be a good option?
Thanks,
TractormanBill
Thanks,
TractormanBill
Keep in mind that if you run a saginaw pump that was originally used for a power steering box the pump's outlet fitting (flow valve) will be too large for a (rack and pinion) steering rack.
You can buy the correct size fitting. I used this one I bought from speedway motors.
Here's an article pertaining to this as well. Good luck.
Wally
Wally
I probably won't go to the serpentine system but I need to look ahead and figure out:
what and how many crank pulleys to use (I not have 2 now), will add AC compressor along with P/S pump and if I can retain the GM alternator which I have mounted now on the right side.
I just don't won't to get too many things bought and then have to back up to get a dependable unit.
Thanks for any suggestions.
TractormanBill
TractormanBill
The Saginaw pump is a popular upgrade with the early bronco guys.
Here's a link for a bracket
http://broncograveyard.com/bronco/i-...racket-v8.html
ike55
04-03-2017 09:29 AM
armyaviation
18
03-12-2017 01:30 PM
BigBlueCat
12-29-2016 02:12 PM
johnnydevil55
04-08-2013 07:01 PM
ferguson777
22
09-02-2003 04:38 AM
