08 E350 5.4L dash light
01-08-2014, 07:07 AM
on
I'm getting wrench light on panel (Limp Mode) . Also the check engine light stays on. Anyone else ever have this problem? I didn't get it scanned yet for codes.
01-10-2014, 12:13 PM
on
That means severe misfire that will damage catalytic converters. Since the factory emission parts cost thousands I would not operate engine.
01-13-2014, 01:01 PM
on
Quote:
Originally Posted by
jesse5
If you know, is it some sensor causing the misfire?
01-13-2014, 02:19 PM
on
A likely cause is an ignition failure. Sparkplugs and coils need to be checked. Ford's do not always set a misfire code for defective coils.
02-11-2014, 03:25 PM
on
I bought a scanner and 2 codes came up. Both were Throttle actuator was stuck closed. I need a new throttle assembly
Trial and Error
07-06-2005 04:01 PM
alopez2
11-29-2004 06:54 PM
BigGatorMike
1997 - 2003 F150
10-17-2004 09:46 AM
Katzen
06-20-2003 12:07 PM
terhune1
1999 to 2016 Super Duty
06-05-2002 03:18 PM
