Getting readiness tests to run with dpf delete? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-07-2014, 10:53 PM
Shoo12's Avatar
Shoo12 Shoo12 is offline
Shoo12 is starting off with a positive reputation.
Just bought first diesel about a month ago. It's an 08 6.4 that already had from the manifolds back straight 4" exhaust dpf gearboxz delete chip. Everything works great and I'll never go back to a gas truck. Problem is I'm needing to get one of two readiness tests to run to to pass a certain test without putting the stock exhaust back on. Any suggestions or tricks? The two readiness tests not running are EGR and catalytic Thanks
Old 01-08-2014, 06:12 PM
Shoo12's Avatar
Anyone out there? First post zero replies. Sweet site. Wicked helpful.
Old 01-08-2014, 06:22 PM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
There is no magic unless you find it, if you have to pass emissions testing, you probably are going to put it back on to pass.
Old 01-08-2014, 06:57 PM
Shoo12's Avatar
Thanks for the response bubba
Old 01-08-2014, 07:33 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
passing without the emissions components will be difficult. Anyone you know that you can run it through first?
A lot of states also do a visual inspection so that may prove difficult to pass.
Old 01-08-2014, 07:40 PM
Shoo12's Avatar
They've already visually okayed it and he said it only has to run one of those 2 tests to get the sticker
Old 01-08-2014, 07:47 PM
Shoo12's Avatar
Didn't know if you could jumper wire a sensor to make it run a test or force a test with a scan tool then delete the fail code.
senix's Avatar
With the gear box z on a stock power setting and clean air filter it might pass at idle if they don't rev it.
Old 01-08-2014, 08:15 PM
Shoo12's Avatar
It's got a relatively new h&s filter on it. Tried city driving, highway, and idle for long periods.
Old 01-09-2014, 09:23 AM
p8ntballn2's Avatar
p8ntballn2 p8ntballn2 is offline
p8ntballn2 is starting off with a positive reputation.
do they hook something up to your OBD II port and run the test? or do they put something in your tailpipe? how is the test conducted?
Old 01-09-2014, 05:25 PM
Shoo12's Avatar
It's not a sniffer test. It's obd2 and it's reading egr test not ready and cat not ready
Old 01-09-2014, 05:27 PM
Shoo12's Avatar
Only need 1 of the 2 to pass
Old 01-10-2014, 07:00 AM
Mystic_Cobra's Avatar
Mystic_Cobra Mystic_Cobra is offline
Mystic_Cobra is starting off with a positive reputation.
It makes sense that those two are reading "not ready" if they are disabled. I guess you are looking for a way to trick the computer. I've never heard of or seen anything. I'm thinking you'll have to put it back to stock to pass those tests.
Old 01-10-2014, 06:59 PM
Shoo12's Avatar
I figured that was the case. I was just hoping there was a way around putting that power and fuel sucking exhaust for a day just to take it right back off
Old 01-11-2014, 06:42 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
IF you have a drive by test like CO does you could try driving by and letting completely off the pedal when you role by the tester. I've heard that is a way to get by them with gas engines at least.
Newbe thewestie 6.7L Power Stroke Diesel 5 02-19-2017 09:25 PM
DPF Test Pipe question nieburb 6.4L Power Stroke Diesel 23 06-24-2016 01:40 AM
DPF Delete and EGR Block Plates Serik 6.4L Power Stroke Diesel 10 06-30-2015 10:34 AM
6.4 open downpipe OH6.4MAN 6.4L Power Stroke Diesel 1 01-04-2014 07:30 AM
2010 DPF and Exhuast Questions mdhnatow 1999 to 2016 Super Duty 2 10-05-2010 10:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
