Getting readiness tests to run with dpf delete? - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-12-2014, 10:09 PM
brian1253 brian1253 is offline
brian1253 is starting off with a positive reputation.
Could you enable the cat and hook up the required sensors but keep the one after where the cat should be out in a plastic bag zip tied on the frame rail to read clean if they say it's reading to clean then ask for a green sticker for being good for the environment but try to hide it the best you can don't leave it in plain sight. That way you don't have to put a cat on
Old 01-13-2014, 12:55 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
If you have visual checks like we do here in SJ, I think you have no choice but to reinstall everything. They opened my hood to look for missing parts and also looked under the truck to ensure the 'pieces' are all there...
Readiness tests take about 100miles of varying driving conditions and at least a couple cold-start drive cycles to clear if I remember right..
Newbe thewestie 6.7L Power Stroke Diesel 5 02-19-2017 09:25 PM
DPF Test Pipe question nieburb 6.4L Power Stroke Diesel 23 06-24-2016 01:40 AM
DPF Delete and EGR Block Plates Serik 6.4L Power Stroke Diesel 10 06-30-2015 10:34 AM
6.4 open downpipe OH6.4MAN 6.4L Power Stroke Diesel 1 01-04-2014 07:30 AM
2010 DPF and Exhuast Questions mdhnatow 1999 to 2016 Super Duty 2 10-05-2010 10:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
